72 Challenger - 318 - 904 (I have no history or details on the trans)
The car started making a pecking sound when in gear or neutral. The sound reminded me of a loose rocker arm. I noticed that the car only made the sound when not in park. My thought was loose converter bolt or bent inspection plate. I was dropping my wife off at work and an old time mechanic hollered that my fly wheel was loose. I checked the converter bolts and sure enough one was stripped. I repaired it but the sound persisted. The inspection plate was good too. Dropped the trans and all the flexplate bolts were tight. When I took the converter out of the trans I noticed a clunking sound in the converter. I can shake the converter (not violently either) and there is definitely something moving inside. Is this normal?
My plans are to install a transgo kit and new converter if you guys agree that the converter is most likely the source of the noise. The trans isn't slipping and seems to operate fine.
I would also appreciate converter recommendations. Warm 318 street driven, 2.76 gears. I'm thinking 2200-2400 or so stall?
Randy
