good luck fitting that 440 in a 88 frame
there is a reason the bouchillon BB swap kit only goes to 87
the 88 has diff mounting locations and frame shape under the engine
I got an 88 frame out back and it wont bolt in,not saying you cant make it fit and work but bolting it in with stock mounts and all is not gonna work IMHO
the tranz xmember is diff also
I just put a 440/727 in an 85 frame and used all stock pieces to bolt it in just like factory
remember also 2 wheel and 4x4 BB engine mounts are diff and wont swap out either,4x4 mount for 4x4 only ect..
yea use the pump in the tank with a dead head reg at the carb or use one with a return line
that can be bypassed and made work with the key..pcm controls sux..
I used my 88 cab and swap the whole wireharness to an 85 wireharness to get rid of the tbi wireharness and the pcm that runs the alt charging and fuel pump stuff
bypassing and running the alt and pump is not that hard to do but I dont do to much wireing myself
so went with the 85 harness to make it mucho easy
good luck
