Front Disc Upgrade #590740
01/22/10 01:09 PM
01/22/10 01:09 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Alright I know I ask way to many questions but standing around the coffee pot this morning the question was thrown out there::
Is there a simple Rotor and bearing swap on a 72 swinger with disc breaks to go to the large bolt pattern?? Currently the guy uses the small bolt pattern rotors and had them drilled to 4.5.
Just asking, now for the information Highway to open up.
Thank you
Kiddart
Re: Front Disc Upgrade [Re: Kiddart] #590741
01/22/10 05:43 PM
01/22/10 05:43 PM
AndyF Online content
AndyF  Online Content
Not that I know of. Some folks try using Mustang rotors on there and I guess it kind of works but I've never tried it myself.
Re: Front Disc Upgrade [Re: AndyF] #590742
01/22/10 06:32 PM
01/22/10 06:32 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Is the only difficulty with this swap the inner wheel bearing difference between the rotors? If so, what about the Scarebird bearing adapters to put later rotors on a 70/71 B or E body?
