Re: porting -1,s for street
[Re: B G Racing]
#590712
01/22/10 12:39 PM
01/22/10 12:39 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Bowl port,blend and gasket match is your best money spent.Leave as much support at the valve guide as possible. No need for full porting.
A street car needs good port velocity to make good mid range torque and power, keeping the port as small and eff as possible would be key here..Bigger isnt always better, in a race car were low gears, loose converters were they leave the line at 5K, and shift at 6800+.
Even on that stroker engine, with the correct cam, that engine will need to shift at 6600+ minimal...And closer to 7K. Thats were these heads work well at.. I ran these heads on the street, but I ran a bit more compression also.. I first ran in with a 509 Hyd cam, then later switched to a MP 590 before going to a roller...So I have a little experience with these on the street.... Car was a heavy 69 Coronet with a 493..It ran 7.20's with the MP 509 in the 8th mile on pump gas, and 3.55 28x10.5 tire gears. 9" T/A converter.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: bonefish]
#590717
01/22/10 03:26 PM
01/22/10 03:26 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
when i get ready to freshen this motor i was thinking of going up a point or 2 in comp.do you think that would utilize these heads better?i wish i could remember what cam i have,its got a pretty loose 10 in conv. in it.i really dont think my entire combo is right on, so ill be looking at every thing. its a 69 b-body,4,129 lbs,best of 7.50 in the 1/8.this motor just seems sluggish,no snap.
That's alot of weight!! That much weight will smooth any "snap" the engine might have. One thing about the -1's is the port speed is very very slow!! Speed it up, use a good fast opening ramp on the intake and slow opening ramp on the ex. and that will improve the port speed in the intake tract. Compression (assuming you use the right fuel octane)will help a bunch as well.
Brian Hafliger
