Hood springs on 69 Dart #590636
01/22/10 02:46 AM
01/22/10 02:46 AM
NM,USA
blown1969 Offline OP
NM,USA
I need some help....how do you go about putting the hood springs (coil type) back on to the hood hinges without dismanteling the entire front end??? Just trying to find out if there is a better and/or easier way to do this....The car is a 69....Thanks
Re: Hood springs on 69 Dart [Re: blown1969] #590637
01/23/10 12:59 PM
01/23/10 12:59 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Remove the splash shields and pry the hinges off the two attaching points. They're on there with push-on clips. Taking the whole hinge out to work on them is the only way to attach the coils. Here is the only pic I have of that area. Notice the hinge is already loose from the top pin.
Re: Hood springs on 69 Dart [Re: GODSCOUNTRY340] #590638
01/23/10 02:32 PM
01/23/10 02:32 PM
NM,USA
NM,USA
Thanks for the reply GodsCountry...I figured it would be nightmare..ish to get them back on!! I'll give it a try and see if I can get it done....again, thanks for the help!
