1970 Super Bee manifolds
#59058
05/18/08 12:35 AM
05/18/08 12:35 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
I am pulling these manifolds from my '70 Bee. Going with headers. My question is: Are these the original manifolds to my car? 383 #'s matching SPD - 1/19/70 First manifold: drivers side - 2291865-1 (11*24*69) Second manifold: pass side - 2899879 (1219)? I am assuming the 11/24/69 is a date and if so, it appears correct for the car. Since the other manifold is in exactly the same condition, I also presume it is original as well... but ? Now then, if I let these go, will I regret it? Hard to find again? I'll never ever want to reinstall them, but I wonder how important they will be to the next owner of the car... opinions?
Re: 1970 Super Bee manifolds
[Re: PAINT IT BLACK]
#59059
05/18/08 12:45 AM
05/18/08 12:45 AM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
ALWAYS keep the original parts from your car. Even if you never "plan" to sell the car, you will, or a family member will have to do it. It ads to the value to have those original parts. Air cleaner, carb, intake , exhaust manifolds etc. should always be kept , even if you don't like them. Someone down the road will want to put the car back correct . Greg Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios We can restore YOUR radio usually in less than 7 days Visit our NEW website.. http://www.wardsclassiccarradiorepair.comgregward@mchsi.comphone 256-852-0955
[Re: BigMoneyLewis]
#59060
05/18/08 01:11 AM
05/18/08 01:11 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Factory HP logs for B body cars can fetch a good dollar. Year one sells repros for even more money. Keep them.If you-or anybody else- ever go back to stock you will be happy that you did hang onto them. FYI,the right manifold also fits C body cars,so there is even more demand for that side. I should know.Every C I seen in a yard that was HP log equipped was raped of its right log to a B body resto..
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
#59062
05/18/08 08:33 AM
05/18/08 08:33 AM
Unless you transposed some numbers on the driver side,you manifolds are wrong. Driver side should be #2951865.Passenger side is #2899970.
891
#59063
05/18/08 09:50 AM
05/18/08 09:50 AM
PAINT IT BLACK
Houston Texas
What book are you looking at?
#59064
05/18/08 11:58 AM
05/18/08 11:58 AM
1970 Chrysler parts manual.
The number that you listed for the driver side beginning with the # 22 would be a 1962 beginning year casting number.
#59065
05/18/08 04:53 PM
05/18/08 04:53 PM
PAINT IT BLACK
Houston Texas
oops. Don't know how that happened. I DID screw the numbers up. The numbers on my drivers manifold are 2951865-1.... so the "9" in the second digit means it is a '69 date code I suppose. I guess these are the originals. I guess everything's got a price. I'm gonna go see how much I can get for them. If it is in the $500 or above range, I just can't justify keeping them. That goes a long way toward a set of TTI's. If it's $250 or so, I think I'll gladly hold onto them.
[Re: 70440+6bbl]
#59068
05/19/08 01:22 AM
05/19/08 01:22 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
'70-'71 manifolds usually don't get above $300 on ebay / $250 at shows. the parts catalog may have the part numbers not the casting numbers LH - part #2951864 / casting #2951865 RH - part #2899968 / casting #2899879 I'd "assume" the date on your RH manifold is 12/1/69 & both to be original to your car!! (1 week after the LH)
#59069
05/19/08 01:34 AM
05/19/08 01:34 AM
6bblgt
Las Vegas, NV
Good "rule of thumb", but there are plenty of exceptions: almost 1000 - 34xx xxx series numbers used in the '69 parts catalog.
[Re: 6bblgt]
#59071
05/19/08 06:44 PM
05/19/08 06:44 PM
just check another casting number source,casting #2899879 equates to BCE 383 2bbl and 440 LP.#2899970 is listed as 383/440 HP.
[Re: 70440+6bbl]
#59072
05/19/08 07:26 PM
05/19/08 07:26 PM
I have yet to see a set of the '70-1 HP manifolds go for more than $350.pr... I'd gladly sell off my collection for $600. per set
Me too
