Best way to notch bores / chamfer cylinder bore tops? #590313
01/21/10 04:38 PM
01/21/10 04:38 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
The shop that did the machine work on my 448 block did a really crappy job chamfering the tops of the cylinder bores. Since I'm going to have to clean up their work, I figured I should notch the tops of the bores for valve-to-cylinder wall clearance, too. What's the best approach to do both of these jobs? Any special tools recommended? The top ring lands are only about .250" down from the piston crown, so there's a limited amount of room to work in. Thanks. - Brad
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590314
01/21/10 04:44 PM
01/21/10 04:44 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Do you're head gaskets have an offset for the valves? If they do use it as a guide, otherwise I wouldn't do the reliefs.
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590315
01/21/10 04:45 PM
01/21/10 04:45 PM
Are you sure you need to notch the bores for valve clearnance? As far as chamfering the bores it take a special tool on the boring bar or a conical tapered stone that can be used on a drill motor, they work, there crude also.
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590316
01/21/10 04:53 PM
01/21/10 04:53 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Using a steel shim I clearenced/relieved the head chamber at its tightest spot at the valves.
I then marked the gasket at its relieve points and transfered that same clearence to the block using it as a Template for chamfering.
To save Compression I didnt chamfer the exhaust as much, as I feel the intake side is the most benificial. I used a medium bit carbide grinder.
The results before and after with the Intake valve set at .550 lift was very appearant as viewed from the bottom side of the clyinder. mike
EDIT, Also it wasnt done for clearence. It was done for a smoother more open intake flow near its highest velocity flow path. At minumum, I think all the BB engines could see a improvement by at least breaking the Sharp bore edges at those points.
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590317
01/21/10 04:57 PM
01/21/10 04:57 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
I prefer the shop not chamfer the top.
As far as unshrouding the block, blue up the deck surface and then put the heads on the bare block. Reach up through each cylinder and mark the deck where the chamber wall lies around the outside of each valve. Off with the heads and out with the die grinder. You can make a ref mark in the cylinder to stay above if need be, but .250 down is a mile. Good Luck
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590318
01/21/10 04:58 PM
01/21/10 04:58 PM
AndyF Offline
AndyF  Offline
Maybe a carbide bit or a 38 grit sanding roll. The sanding roll works better for me but some guys are skilled with the carbide bit.
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: Sport440] #590319
01/21/10 07:35 PM
01/21/10 07:35 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
getting ready to do my smallblock the very same way as you explained.
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590320
01/21/10 08:41 PM
01/21/10 08:41 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I used the head gasket as a template after I checked it against the head. Blued and scribed. Carbide burr and sanding rolls. I did it before the final machining.
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590321
01/21/10 08:52 PM
01/21/10 08:52 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
in victorylibrary.com in the tech page section there is a writeup/how to on this.
http://victorylibrary.com/mopar/chamber-tech.htm
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: blownzoom440] #590322
01/21/10 09:01 PM
01/21/10 09:01 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
My stuff looks just like BSB67's stuff.
Don't be scared, fire up the carbide
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: scatpacktom] #590323
01/21/10 10:04 PM
01/21/10 10:04 PM
I would make sure I knew where the top ring travel ends before I started (and I do on motors that need chamfering) chamfering the cylinder walls, no sense in going to deep and hanging a ring up and breaking it or allowing all of the compression to blow by the top ring Measure three times, cut once
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: Cab_Burge] #590324
01/21/10 10:09 PM
01/21/10 10:09 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I just go half way to the top ring and scribe a line.No big deal
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590325
01/21/10 10:14 PM
01/21/10 10:14 PM
BradH Offline OP
BradH  Offline OP
Thanks for all the replies. I'm interested in doing it for airflow reasons, too.
Re: Best way to notch bores / chamfer cylinder bore tops? [Re: BradH] #590326
01/22/10 03:03 PM
01/22/10 03:03 PM
Canada
RobR Offline
RobR  Offline
Canada
How bad could it be ??? post a picture or two..
