Page 2 of 3 1 2 3
Re: STOP on a dime? NOT! #58995
05/18/08 09:30 PM
05/18/08 09:30 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
See if you can borrow one of those "phoenix injectors" that reverse bleeds the system, basically pushes the air back to the MC from the bleeder screw. I have a tech friend who swears by it. Worth a shot.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: STOP on a dime? NOT! [Re: bschargerse] #58996
05/18/08 09:39 PM
05/18/08 09:39 PM
Anonymous OP
Anonymous OP
never heard of those. i'll ask when i go get the vac. bleeder.
Re: STOP on a dime? NOT! #58997
05/19/08 12:13 AM
05/19/08 12:13 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
porportioning valve problem, I never thought they could go bad, dont know whats in them, check valves, or balls but they do go bad and sounds like this could be one of them... remember when you compress the calips your pushing fluid back when its supposed to be going the other way?????
Let us know please....
Re: STOP on a dime? NOT! [Re: quick77rt ] #58998
05/19/08 12:28 AM
05/19/08 12:28 AM
Anonymous OP
Anonymous OP
replace BOTH p-valves. notta
i keep the m/c cap of when i push the pistons back.
but i'll tell yah.. so far i'm lookin' like a clown in my customers eyes.
Re: STOP on a dime? NOT! #58999
05/20/08 04:51 PM
05/20/08 04:51 PM
MD
p d'ro Offline
p d'ro  Offline
MD
So what happened today????? Gotta know... What else would cause the pedal not to come back up? I have heard of an internal break in the rubber line acting like a one way valve, so the pedal will not come back after it is pushed... I would replace the rubber lines. They are probably old as hell...
Re: STOP on a dime? NOT! [Re: p d'ro] #59000
05/20/08 05:27 PM
05/20/08 05:27 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
It's a '97 Neon--hell's way older than that. The collpsed line wouldn't allow the pedal to the floor if everything else was good.
Re: STOP on a dime? NOT! [Re: FuryUs] #59001
05/20/08 06:14 PM
05/20/08 06:14 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If one of the rubber lines was balloning then I could see it as a brake line but the lines are not that old. I would inspect them though
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: STOP on a dime? NOT! #59002
05/20/08 06:42 PM
05/20/08 06:42 PM
So Cal
So Cal
I hate that esp on something as simple as a pad swap.
As long as you find out the problem before the customer does and he does not tow it out before then, you are safe.
Good luck
Re: STOP on a dime? NOT! [Re: HealthServices] #59003
05/20/08 07:29 PM
05/20/08 07:29 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I've found this problem on two Neons, a '96 & '98. Remove both rear drums and make sure the shoes are still attached to the steel mount. They're just glued and do come off. Both cars had very low pedal and the owners couldn't figure it out. The shoes actually came loose and were at the bottom of the drum so when adjusting them you could feel drag but since there was no shoe left at the top, when brakes were applied the wheel cylinders would travel all the way out but push on nothing, causing low or no pedal.
Re: STOP on a dime? NOT! (UPDATE) [Re: GODSCOUNTRY340] #59004
05/20/08 10:50 PM
05/20/08 10:50 PM
Anonymous OP
Anonymous OP
found the problem. my helper wasn't following my orders on when to pump the brakes and when to hold them.
suffice to say.. he's no longer my helper. thanks for all your reply's guys
Re: STOP on a dime? NOT! (UPDATE) #59005
05/20/08 11:41 PM
05/20/08 11:41 PM
So Cal
So Cal
Relying on someone other than yourself is one of the hardest things to do. Hopefully you still have a loyal customer.
oh and thats why I got a brake bleeder a long time ago.
Re: STOP on a dime? NOT! (UPDATE) [Re: HealthServices] #59006
05/20/08 11:47 PM
05/20/08 11:47 PM
Anonymous OP
Anonymous OP
yah, i did it myself. jar filled with brake fluid and a hose from the bleeder to the jar.
i didn't charge her for all the extra stuff, wasn't her fault.. so i ate it.
she was very happy
Re: STOP on a dime? NOT! (UPDATE) #59007
05/20/08 11:50 PM
05/20/08 11:50 PM
dead center
CHRONiklyDEMONic Offline
Demonized
Demonized
dead center
LOL!
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: STOP on a dime? NOT! (UPDATE) [Re: CHRONiklyDEMONic] #59008
05/21/08 09:20 AM
05/21/08 09:20 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'm glad it's fixed and the customer is happy. I have to wonder though; When I'm at a wheel yelling "Pump" and Hold", I can feel the pressure changes. Either the instructions were not good, or the guy was really dumb. I've had (stereotype warning) blonde exotic dancers be able to perform the driver's seat part of the bleeding procedure.
Re: STOP on a dime? NOT! (UPDATE) [Re: RodStRace] #59009
05/21/08 09:31 AM
05/21/08 09:31 AM
Anonymous OP
Anonymous OP
mabey it was me.. who knows..
Re: STOP on a dime? NOT! (UPDATE) #59010
05/21/08 09:58 AM
05/21/08 09:58 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Man thats crazy, my girl cant boil water, but she helped bleed the brakes in my van, if you scream loud enough most will listen.
Glad its fixed, there is always the do it alone method, either a rubber strap on pedal from the backside or the concrete block leaning on the pedal, pop bleader let it go a few seconds re-set block.....
Glad its fixed though, I would of went nuts...thats why I can only work on my on crap.
Re: STOP on a dime? NOT! (UPDATE) #59011
05/21/08 01:41 PM
05/21/08 01:41 PM
I knew that's what it was. I just wanted to see how long it took for you to figure it out.
Re: STOP on a dime? NOT! (UPDATE) [Re: quick77rt ] #59012
05/21/08 03:16 PM
05/21/08 03:16 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
Now that's funny...and true!!
Re: STOP on a dime? NOT! (UPDATE) [Re: VITC_GTX] #59013
05/21/08 11:00 PM
05/21/08 11:00 PM
Anonymous OP
Anonymous OP
very funny
that kid has been retardo since day one. this was just the last straw.
Re: STOP on a dime? NOT! #59014
05/21/08 11:21 PM
05/21/08 11:21 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
delete
Page 2 of 3 1 2 3
