KB 190'S Will I need to machine? #590035
01/21/10 01:04 PM
01/21/10 01:04 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I was going to put KB 107 in my 360 now I'm leaning towards the little added compression of the KB 190'S
looking at mancini's web site it says additional machining will be required is this correct My block is Zero decked and I'm using stock open chamber cylinder heads last 3 casting numbers are 596. I was thinking I should be able to just put them in.
Re: KB 190'S Will I need to machine? [Re: flatiron] #590036
01/21/10 01:29 PM
01/21/10 01:29 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The KB190s should fit without anything special........barring your
pistons aren't +.080 above the deck or heads milled to nothing.
BTW, you can't say you have a "zero deck" block without all the components.
Re: KB 190'S Will I need to machine? [Re: S/ST 3040] #590037
01/21/10 01:31 PM
01/21/10 01:31 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Ok I'll give ya that I was going by the Blueprint measurement of 9.588 from crank centerline to the bank
Re: KB 190'S Will I need to machine? [Re: flatiron] #590038
01/21/10 03:02 PM
01/21/10 03:02 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
They'll clear fine.
I'm at .010 deck with those pistons and have room to spare.
edit...I have 191's and have room.
Re: KB 190'S Will I need to machine? [Re: abodiesonly1] #590039
01/22/10 01:12 AM
01/22/10 01:12 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
