94 caravan, front end clunk #589781
01/21/10 10:26 AM
01/21/10 10:26 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
94 caravan. on right hand turns it makes a clunking noise on the drivers side of the van. like a rotational noise. i am thinking the cv is toast but doesnt make the normal worn out cv noise, this is a metallic loud banging that goes on as long as its turning right that you can feel in the steering wheel. everything is in good shape underneath. recent tie rods+struts (3000miles) but he cv is original.
any thoughts other than dont turn right?
Re: 94 caravan, front end clunk [Re: chrisf] #589782
01/21/10 11:20 AM
01/21/10 11:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check the wheel bearing.They will clunk like that when they start going bad.If you are lucky it will be the CV.Those bearings are a pain to replace.Rocky
Chrysler Firepower
Re: 94 caravan, front end clunk [Re: chrisf] #589783
01/21/10 11:38 AM
01/21/10 11:38 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
make sure the engine mounts aren't toast letting the engine move around bottoming out the cv joint
Re: 94 caravan, front end clunk [Re: gtx6970] #589784
01/21/10 09:51 PM
01/21/10 09:51 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
thanks guys i will check those out and see what i can find
