build numbers and build sheet question [70 RR ] #58923
05/17/08 02:52 AM
05/17/08 02:52 AM
Gold Coast, Australia.
6pacdave Offline OP
6pacdave  Offline OP
Just interested to find out how many 70 RR coupes with a 383, 4spd w/airgrabber were built?.Or otherwise,the total number of airgrabber cars in 70 RR's.
All I can find on the net is that 5839 coupes w/383 & 4spd were built?.
Also on my build sheet it has "13 OIL UNIT" typed in large black letters in the remarks column at the botom of the sheet, any info on this?
cheers n thanks Dave
70 GTX 70 Chevelle SS396 69 Mustang F'back
Re: build numbers and build sheet question [70 RR ] [Re: 6pacdave] #58924
05/17/08 12:28 PM
05/17/08 12:28 PM
Gabba Gabba Hey! NYC
Diego (not Ted) Offline
You cannot determine a combination of options for a car, so it's only possible to find how many 4-speed 383s were built, or Air Grabber cars, but not both. Anyone who tries to combine options is being statistically misleading.
I have the numbers you seek, but why not give us more info about your car (like color) and then I'll give you more info.
Re: build numbers and build sheet question [70 RR ] [Re: 6pacdave] #58925
05/17/08 01:07 PM
05/17/08 01:07 PM
CT, USA
RM23V1 Offline
RM23V1  Offline
CT, USA
Refers to the installation of an oil pressure gauge and sending unit. Most cars built at the factory were grocery-getters and didn't call for one.
Re: build numbers and build sheet question [70 RR ] [Re: RM23V1] #58926
05/18/08 03:42 AM
05/18/08 03:42 AM
6pacdave Offline OP
6pacdave  Offline OP
Heres some more info.
Its a VY1, H2X9,black bench seat, air grabber, 4spd, N code 383. Plant code is G. Has a tach w/clock.
Some b/sheet codes are eng,63,trans 21,axle53,
carb fresh air 966.wheels 23, brakes 11.
Not sure what other info you need but let me know if you req more to maybe help ya?
cheers Dave
Re: build numbers and build sheet question [70 RR ] [Re: 6pacdave] #58927
05/18/08 10:05 AM
05/18/08 10:05 AM
I assume you mean "FY1"?
Re: build numbers and build sheet question [70 RR ] [Re: Diego (not Ted)] #58928
05/18/08 04:11 PM
05/18/08 04:11 PM
6pacdave Offline OP
6pacdave  Offline OP
Yes, slight typo, lemon twist ya.
cheers Dave
Re: build numbers and build sheet question [70 RR ] [Re: 6pacdave] #58929
05/20/08 09:31 AM
05/20/08 09:31 AM
Sorry, have been busy - bump this up if I'm taking too long for the info that you seek.
Re: build numbers and build sheet question [70 RR ] [Re: 6pacdave] #58930
05/22/08 07:15 PM
05/22/08 07:15 PM
OK, you want answers? I've got answers!
If your car is a US-spec RR coupe, these numbers describe it to a T:
FY1 - 1168 (4th most popular color)
H2X9 - 7642 (most popular by a landslide)
N96 - 2672
N85 - 1508
W23 - 3459
Hope this helps!
Re: build numbers and build sheet question [70 RR ] [Re: Diego (not Ted)] #58931
05/22/08 08:36 PM
05/22/08 08:36 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Diego, how did you get these numbers? I have been searching for similar info on my 69 GTX convert, and everyone says that it isn't available. FYI it is a triple black 440, console a/t, air grabber WITH hood stripes. Any ideas on this?
Re: build numbers and build sheet question [70 RR ] [Re: TrueTripleX] #58932
05/22/08 09:04 PM
05/22/08 09:04 PM
I have some reports from Chrysler by option.
I don't know if I have '69 GTX stuff. But I can tell you off the bat that no colors exist for '69s - that started in '70 except for those cars ordered with the buffed silver paint.
Re: build numbers and build sheet question [70 RR ] [Re: TrueTripleX] #58933
05/22/08 11:03 PM
05/22/08 11:03 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Console - 71.3% ~ 393 cars
440 w/ automatic - 65.7% ~ 362
Air Grabber - 29.6% ~ 163
V21 hood stripe - 20.5% ~ 113
You can't cross reference options so there's no way to know how many cars with Air Grabber and hood stripes.
(I'll swap ya for the VIN and SPD info See my signature)
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: build numbers and build sheet question [70 RR ] [Re: 69CoronetRT] #58934
05/23/08 03:53 PM
05/23/08 03:53 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
69CoronetR/T you have a PM
Re: build numbers and build sheet question [70 RR ] [Re: TrueTripleX] #58935
07/13/08 08:10 AM
07/13/08 08:10 AM
6pacdave Offline OP
6pacdave  Offline OP
Thanks D.
Ive been away so a bit slow on the reply sorry.
Wouldnt have thought the airgrabber was so popular. No breakdown on 4 speeds??
cheers mate Dave
Re: build numbers and build sheet question [70 RR ] [Re: 69CoronetRT] #58936
07/13/08 11:33 AM
07/13/08 11:33 AM
Why don't the figures between Diego (not Ted) and 69CoronetRT add up?
N96 - 2672 vs. Air Grabber - 29.6% ~ 163
Re: build numbers and build sheet question [70 RR ] #58937
07/13/08 04:01 PM
07/13/08 04:01 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Diego is talking about 70 RR's (the original post).
I replied to a new question on 69 GTX's
Seeking:
