Dome pistons with eddy rpm heads #588891
01/20/10 07:16 PM
01/20/10 07:16 PM
New Hampshire
n_bogie1984 Offline OP
New Hampshire
I am running a 440 with a 4,15 stroke crank, eagles h beam rods with a .990 pin. am currently useing srp 4.375 bore -4 cc flat tops, that are sitting .012 in the hole. heads are the 84cc version of the eddy rpms which have been milled down .050 to around a 74cc. camshaft will be in the mid to high .600 range. and would liek to have around a 14.5 to 1 comp ratio when said and done. any ideas?
Re: Dome pistons with eddy rpm heads [Re: n_bogie1984] #588892
01/20/10 07:24 PM
01/20/10 07:24 PM
AndyF Offline
AndyF  Offline
Call up the guys at Diamond Racing Pistons and see what they say. They have an Edelbrock dome so maybe they can get you there.
Re: Dome pistons with eddy rpm heads [Re: n_bogie1984] #588893
01/20/10 08:32 PM
01/20/10 08:32 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Like Andy said, Diamond will hook you up. I highly suggest you talk to Mike @ CRE for the best price. I recently priced a set of Diamonds with 2 Moparts vendors and they were $300 apart, so it does make a difference where you buy them. That said, you can't possibly need much of a dome. Probably 4 cc's, maybe 6 cc tops? Diamond has an Eddy dome profile in their catalog, so it won't be much of a problem for them.
Re: Dome pistons with eddy rpm heads [Re: 64Post] #588894
01/20/10 09:00 PM
01/20/10 09:00 PM
New Hampshire
New Hampshire
i was figureing more along 10-14 cc to get the comp up, pretty much shooting for as much comp and i can and not have contact
Re: Dome pistons with eddy rpm heads [Re: n_bogie1984] #588895
01/20/10 09:14 PM
01/20/10 09:14 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yeah, 10 cc's would just about do it.
It's a shame your heads are milled and you're not running a 4.25 crank because I've got a new set of 14 cc Diamond Eddy domes that match your other specs sitting on the shelf.
Re: Dome pistons with eddy rpm heads [Re: 64Post] #588896
01/20/10 09:33 PM
01/20/10 09:33 PM
New Hampshire
New Hampshire
well my class has a 500 ci limit so it now has become who has the most compression game. hopeing ill be able to get 700 hp out of her
