Valve Stems #588857
01/20/10 06:33 PM
01/20/10 06:33 PM
San Gabriel, CA 91775
rexus31 Offline OP
rexus31  Offline OP
For a 1965 Chrysler, what length valve stem should I install if I plan on running factory hub caps?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Valve Stems [Re: rexus31] #588858
01/20/10 08:09 PM
01/20/10 08:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Factory shipped with standard length with about 1 inch extensions. Readily available at about anyplace including Wally world.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Valve Stems [Re: MoparforLife] #588859
01/21/10 08:13 AM
01/21/10 08:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just use the long valve stems unless you want concorse correct.Those extensions are a pain and Ive had them at the shop when they stick when you check pressure and deflate the tire.When I ran the 66 Imperial caps I had to run the real long ones.Rocky
Chrysler Firepower
