Build sheet wheel code question... #588785
01/20/10 05:25 PM
01/20/10 05:25 PM
Idaho
CANDK Offline OP
CANDK  Offline OP
Idaho
My 71 Challenger has a couple codes I cant figure out...
On line #2, after the T-U-W code, there are two 'W' boxes; mine is W34, which is collapsible spare, but anyone have an idea what size/make it would be? The car came with U82 tires (E60-15) if it helps...
On line 4, wheels are coded 'road 50' 'color TX9' 'spare 13' and then 'wheel cover 54'.
Any ideas?
Re: Build sheet wheel code question... [Re: CANDK] #588786
01/20/10 05:58 PM
01/20/10 05:58 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
2944450 15x7 black (TX9) painted steel wheels with 2944454 red circle Dodge dog dish hubcaps
Re: Build sheet wheel code question... [Re: Mastershake340] #588787
01/21/10 09:13 AM
01/21/10 09:13 AM
cataclysm80 Offline
cataclysm80  Offline
Those hubcaps are available reproduction aren't they?
Tav
Re: Build sheet wheel code question... [Re: cataclysm80] #588788
01/21/10 01:41 PM
01/21/10 01:41 PM
Crook County, ILL
Crook County, ILL
Tav
Someone was advertising repros a while back (maybe BE&A?), they weren't cheap, over $300 a set IIRC. I never have seen any in person to see how good they are.
For such a widely used part those dogdish caps are sure hard to find, at least if you are trying to find mint or NOS. When I started compiling a list back in the late 90's of parts I needed to restore my T/A, I thought the caps would be one of the easiest parts to find. 10 years later I have probably bought over a dozen, including some NOS, and I am not sure if I have 4 that are good enough to use! They are aluminum and get dinged and scratched very easily. And if they do get any flaws, they really can't be restored.
I even bought a couple NOS in the box ones a while back that when I got them, I found they were damaged!
On the other hand, a set of properly date coded '450 wheels were one of the first things I acquired when I started my parts hunt, and I thought those were going to be some of the hardest parts on my list to find.
Update: after I posted I checked B/E and A's website and they do have red circle dog dish hubcaps for $325 a set. However, they are the stainless steel version, which look pretty much the same as aluminum. But they don't have the aluminum version, which came out sometime in early 1970 I believe, and was the material used from then on.
Re: Build sheet wheel code question... [Re: Mastershake340] #588789
01/22/10 04:46 AM
01/22/10 04:46 AM
Idaho
CANDK Offline OP
CANDK  Offline OP
Idaho
Thanks for your help! I saw the repro caps too, and found a pic of an EV2 car with the setup...
This is going to look awesome!
