Re: W23 RECALL WHEEL 69 fury VIP is home
[Re: ph23vo]
#588601
01/20/10 07:02 PM
01/20/10 07:02 PM
Posts: 4,108 Glen Burnie MD
68SportFury
Glen Burnie MD
I hope you have that piece of moulding for the right quarter. '69 VIP trim is probably even more fun to hunt for than '68 Sport Fury stuff.
Paul 68 Sport Fury ragtop 67 Fury III 4-dr HT 11 Charger Rallye 17 Challenger SXT Plus
[Re: Dingmaster]
#588615
01/22/10 02:50 PM
01/22/10 02:50 PM
Posts: 365 Motor City
Shaker223
Motor City
What does the broacast sheet say for tires? I would expect G78x15 dual line goodyears.
What years/models did that wheel cover come on? From the green car that was posted several posts before this one.
[Re: ph23vo]
#588616
01/22/10 03:40 PM
01/22/10 03:40 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
yep..loose lugs and alum wheels dont mix
"loose lips sink ships" "loose lugs sink boats"! Dan: I want to see the car at the Seattle show or at your place this year!
[Re: ph23vo]
#588618
01/22/10 08:15 PM
01/22/10 08:15 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
Dan,hows the trunk floor in that thing? I have a clean section from a 69 New Yorker if you need it. It's cut between the frame rails,and is cut from the top curve in the front,and has the center part of the rear crossmember on the back of it. PM me if you need it.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
