Correct belt size for big block power steering? #588170
01/20/10 12:59 AM
01/20/10 12:59 AM
San Jose, CA
Blue69Charger Offline OP
San Jose, CA
What is the correct power steering belt size for a 69 charger with a 440, no a/c and a saginaw pump? I have non-a/c 440 pulleys on my 471 hemi. The power steering belt rubs against the water pump pulley under hard load. It is a gates 7440 which has a length of 44". I can't get a finger in between the belt and pulley. Should I try a shorter belt?
Re: Correct belt size for big block power steering? [Re: Blue69Charger] #588171
01/20/10 12:56 PM
01/20/10 12:56 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i would try one an inch or 2 shorter.
Re: Correct belt size for big block power steering? [Re: 05dakota] #588172
01/20/10 02:21 PM
01/20/10 02:21 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I had the same problem with my 67 440 with a TRW pump.. A shorter belt cured the problem BUT, the clearance is very close still...
Re: Correct belt size for big block power steering? [Re: minivan] #588173
01/20/10 02:37 PM
01/20/10 02:37 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Same thing on my '66 Satellite Hemi....and a freind of mine has a '66 Charger Hemi and the belt rubs periodically too. Never comes off or anything, just dulls up the fan pulley.
One of those HEMI things!!
Re: Correct belt size for big block power steering? [Re: superwrench] #588174
01/20/10 09:11 PM
01/20/10 09:11 PM
San Jose, CA
San Jose, CA
Thanks guys. I will try putting the shortest belt I can get on it.
