will aluminum heads make a difference on my motor?
#587862
01/19/10 07:15 PM
01/19/10 07:15 PM
Posts: 233 vashon island washington
hunterstroble
I have a 440 in my challenger, i don't race it anymore, just cruise with the kid. I have a 440 with 11-1 compression, .505in .505 exh 290 duration isky solid lifter cam, 1.5.1 roller rockers, 452 heads with 2.14 and 1.81 stainless valves, bowl ported and other port work and a three angle valve grind. An m1 single plane intake and 850 holley with a proform hp center body. My question is will I gain anything with a set of eddy or 440 source heads. I don't want to increase my cam or carb because I like the drivabilty of the componation. Thanks.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
Re: will aluminum heads make a difference on my motor?
[Re: AndyF]
#587866
01/19/10 07:42 PM
01/19/10 07:42 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I noticed a big difference when I bolted on my Edy's OOTB but my old Iron heads were untouched.
[Re: BeEtLeJuIcE !]
#587867
01/19/10 07:51 PM
01/19/10 07:51 PM
hunterstroble
I use 92 octane at 36 degrees total timing, no detonation, i swapped to the thim sheet metal gaskets last summer and there were no detonation marks either. I'm just wondering by swapping heads if there will be 1000 dollars difference.
[Re: AndyF]
#587869
01/19/10 07:55 PM
01/19/10 07:55 PM
RapidRobert
Hypothetical Q: If a person replaced a set of 452's w a set of eddies and the chamber/port dimentions were IDENTICAL on each (1) what would be the difference in performance (if any) and (2) With the aluminum conducting heat faster would that be what would be making this difference (if there's a difference)? and (3) if the eng (w the 452's) was at the ping limit with his current choice of fuel (and his current CR) if the SCR was was raised (w NO other changes) would he be able to run the same octane w no pinging? and (4) if so would there be a gain in power (w the higher CR/alum heads (which'd be wicking away heat)?
[Re: hunterstroble]
#587870
01/19/10 10:08 PM
01/19/10 10:08 PM
Posts: 31,041 Oregon
AndyF
Depends how much money you have. If you're going hungry and the kids don't have shoes then spend the grand on something else. If you have a big toy budget then a set of Edelbrock heads is a logical investment. Better yet buy the Mopar version with the straight plugs so you don't have a hassle with the plug wires.
[Re: RapidRobert]
#587873
01/20/10 12:53 AM
01/20/10 12:53 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The following are just my somewhat educated opinions. I am not a professional engine builder, just a hobbyist. with that said, I'll take a swing at these Q's:
1) IF everything else was the identical, and only the material was in question: none, if anything the iron heads might offer a very slight horsepower advantage, but aluminum weighs less, so your car gets lighter. Advantage Aluminum.
2) The difference would be that just as aluminum dicipates the heat, it also dicipates energy (this is why its good when used at main caps). Since it dicipates energy at a slightly higher rate than iron, the iron heads would create more energy inside the cylinder, hence, slightly more HP. (emphasis on SLIGHTLY)
3) depends on how much you raise the compression. because of the same pricipals noted @ #2, you can use slightly more static compression with aluminum. with that said, If I was the OP, I'd opt for the Eddy large chamber heads to break even, or slightly lower my compression (11:1 is too much for pump gas in my book, even with aluminum heads)
4)more compression generally = more power. but again, at 11:1 on pump gas, I would'nt look to raise it.
Hope that helps, let me know if you dissagree.
[Re: StealthWedge67]
#587875
01/20/10 02:48 AM
01/20/10 02:48 AM
hunterstroble
probobaly lucky, but my car runs really rich, my dad's car had the same combo before he went to a 500 and his did not ping either.
[Re: hunterstroble]
#587876
01/20/10 03:44 AM
01/20/10 03:44 AM
DaytonaTurbo
Manitoba, Canada
No. Your worked over stock heads probably don't leave much on the table compared to OOTB eddys or stealths. Now drop 2000 dollars on a set of CNC ported stealths that flow 310-320cfm and there you'll see some difference!
[Re: RapidRobert]
#587877
01/20/10 03:46 AM
01/20/10 03:46 AM
DaytonaTurbo
Manitoba, Canada
A while back someone on here posted a dyno comparasin from one of the hot rod mags of two chevy motors side by side. Built identically, identical heads except one was iron one was aluminum to test this alum vs iron theory. Results on the dyno, no difference between the two. So if you can up the SCR with the alum heads, it's only a win-win situation for you over the irons.
[Re: hunterstroble]
#587878
01/20/10 09:35 AM
01/20/10 09:35 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
This the cam SOLID .505 .028 290° 254° 108° .505 .028 290° 254 this cam is big enough to help reduce cylinder pressure below 4000 so goes a long way to reducing ping with an iron head. Not enough gain Edlebrock OOTB to spend $1450 IMHO and the Source heads will do nothing The source heads are a far inferior head to the Eddy OOTB they may come close CNC port to CNC port but still a Chinese crap shoot at best!! Now if your were bracket racing the extra 2 3 tenths an OOTB eddy would give means a lot on the street you will not feel it or feel very little
[Re: Dodgem]
#587879
01/20/10 11:59 AM
01/20/10 11:59 AM
StealthWedge67
Puyallup, WA
If you just don't like stuff manufactured by a Chinese person, thats your deal. But to say Stealth heads are crap is just plain stupid. They flow nearly exactly what an Eddy head does, Hundreds of guys right here on this site are using them with little or no trouble, and at $500 less than a pair of Eddy's, there is just no denying the fact that they are perhaps the best bang for buck available for a Mopar big block on the market today. Personally, from a guy with a family and a limited hot-rod budget..... "THANK YOU BRANDON!!!"
#587881
01/20/10 02:33 PM
01/20/10 02:33 PM
WILD BILL
BROOK PARK, OH
GEnsrud, reread Dodgem's post. He didn't say they were crap. He said they were a "crap shoot"
