8 3/4 rearend question #587619
01/19/10 01:53 PM
01/19/10 01:53 PM
calif
cupcake Offline OP
cupcake  Offline OP
calif
on a 8/34 if you take the drive shaft out the tran but leave it in the pinon turn it back & forth how much slop should there be.this thing hass about 5000 miles seams very sloppy i have a 5spd this things realy bangs around.its a sure grip power lock
Re: 8 3/4 rearend question [Re: cupcake] #587620
01/19/10 02:18 PM
01/19/10 02:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Should be .008-.010 pinion slack when you rotate it back and forth. It's best to check it without the driveshaft hooked to it.
Re: 8 3/4 rearend question [Re: stumpy] #587621
01/19/10 02:34 PM
01/19/10 02:34 PM
calif
cupcake Offline OP
cupcake  Offline OP
calif
yes thanks is there a phone # for doc diff cant seem to find one seem to bee bout 1/2 inch it came from randys ring pinion whats the deal is it back lash?????
Re: 8 3/4 rearend question [Re: cupcake] #587622
01/19/10 03:20 PM
01/19/10 03:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Email or PM DrD.
