Nikasil cylinder plating #587587
01/19/10 01:14 PM
01/19/10 01:14 PM
Upland, California
Spode Offline OP
Spode  Offline OP
Upland, California
Nikasil cylinder plating question
I have been involved in racing dirt bikes for most of my life. Most MX bikes have the cylinder plated with nikasil. It reduces friction adds lubrircation. It is somewhat expensive but given the money people put into race engines how come it is not used on car engines?
Re: Nikasil cylinder plating [Re: Spode] #587588
01/19/10 01:19 PM
01/19/10 01:19 PM
If it is a chrome plating many of the Porsche(SP?) motors came with that as well as other aircraft and other air cooled motors used in industry and racing. if it is not the same then
Re: Nikasil cylinder plating [Re: Cab_Burge] #587589
01/19/10 04:56 PM
01/19/10 04:56 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
nikasil is different than hard chrome we had them on our cyls when i raced liquid cooled snowmobiles.
Re: Nikasil cylinder plating [Re: ro23car] #587590
01/19/10 07:30 PM
01/19/10 07:30 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Nikasil is carbide based I think.......I do know that it is harder than a hookers heart and it would take special rings to make work.
I do not see why it wouldn't work on eight holes and would be amazed if it hasn't been tried in Pro Stock .......almost certainly in F-1.
Re: Nikasil cylinder plating [Re: Spode] #587591
01/19/10 08:09 PM
01/19/10 08:09 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
It has been used in race engines to save the block. The theoretical advantages you mention don't seem to show up as horsepower in a gasoline powered V8, so at $3500 for a set of 8 liners I'd be sure it's a block worth saving.
Re: Nikasil cylinder plating [Re: LSP] #587592
01/19/10 08:51 PM
01/19/10 08:51 PM
IN
ahy Offline
ahy  Offline
IN
I believe Nikasil is typically used on an aluminum bore to give it a harder wear surface. That's why motor cycles and snowmobiles use it. I believe BMW started using it in the 90's on their all aluminum V8's to solve a wear problem. Aftermarket aluminum muscle blocks use an iron liner to get a hard surface... that can also be bored. There would be little need or benefit on an iron bore.
Re: Nikasil cylinder plating [Re: ahy] #587593
01/19/10 09:04 PM
01/19/10 09:04 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
can't say who,where or what but nikasil IS being used in full race efforts. its a mother to get the rings to seal up in
Re: Nikasil cylinder plating [Re: Spode] #587594
01/19/10 11:23 PM
01/19/10 11:23 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Mercury Marine has used the Nikasil plating on some of the Hi-perf outboards since about 1988-89. The bore does not wear. The piston skirt does start to colapse. Our rule of thumb at the Lake X test facility was to replace pistons after 75-100 hrs of use. No honing...just slap it together n go! These engines tipically spent ALL their time at about 8200 rpm. Great stuff! Also used by Porsche and Formula 1 teams.
Re: Nikasil cylinder plating [Re: mercman1] #587595
01/20/10 01:10 AM
01/20/10 01:10 AM
tampabucs1 Offline
super gas
tampabucs1  Offline
super gas
Re: Nikasil cylinder plating [Re: tampabucs1] #587596
01/20/10 04:47 AM
01/20/10 04:47 AM
Finland
mafo Offline
mafo  Offline
Finland
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
