I have a set of Ross shelf pistons, part number 80762.
Will they work with 2.25 valves... or will they need to be fly-cut? Thanks
I asked ross in a e-mail pretty much the same question but was a different part number (99539). Their response was: "The pistons are cut at 2.300 we recommend at least .050 radial clearance around the valve. You probably could get away with a 2.250 but it will be tight. You will have to clay the top of the piston and check the clearance"
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
