340 windage tray on a 360 #587335
01/19/10 09:12 AM
01/19/10 09:12 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Will a 340 windage tray fit a 360?
Re: 340 windage tray on a 360 [Re: flatiron] #587336
01/19/10 10:38 AM
01/19/10 10:38 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
They only make one SB tray that I know of. The only thing that you have to watch fro is that some of the rod bolts may hit the tray and you need to space the tray or put small dings in the tray where the rod bolts tap it. Not a major deal but urn the motor over to check before putting the pan on.
Re: 340 windage tray on a 360 [Re: MoparforLife] #587337
01/19/10 10:45 AM
01/19/10 10:45 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Thanks Didn't know if the crank weights would be different internal verus external balance
Re: 340 windage tray on a 360 [Re: flatiron] #587338
01/19/10 10:48 AM
01/19/10 10:48 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
Will not fit, larger mains make the bolt hole spacing wider
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: 340 windage tray on a 360 [Re: GTX70sixpack] #587339
01/19/10 11:05 AM
01/19/10 11:05 AM
I too thought they (the w tray itself) were the same but that they included some very thick washers in the kit to go under those 4 bolts to space them out further so it'd end up clearing the 360 stroke???. I'd rather ditch the washers (for the most main cap bolt thread engagement) and grab some hardware store spacers/longer bolts that screw into the bolt heads to space the tray out that way. But back to the orig Q.
Re: 340 windage tray on a 360 [Re: RapidRobert] #587340
01/19/10 12:02 PM
01/19/10 12:02 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
When sold new they are listed to fit 318 340 and 360. I agree maybe the washers come into play.
http://cgi.ebay.com/ebaymotors/Mopar-318...sQ5fAccessories
Re: 340 windage tray on a 360 [Re: mopars4ever] #587341
01/19/10 01:09 PM
01/19/10 01:09 PM
Upper Midwest
Upper Midwest
They only list one and the spacers and washers do come into play. I got mine used and didn't have the spacers and was not told about the rod bolts in advance so had to improvise. The mounting pad holes are slotted to allow for the spacing of the mounting bolts. Mine is on a shelf in the garage but it is to dang cold out there to go look. I can't use one with my baffled pan.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 340 windage tray on a 360 [Re: MoparforLife] #587342
01/19/10 09:38 PM
01/19/10 09:38 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I took a MP windage tray off the old 318 and bolted it straight onto my stock stroke 360, stock pan 360 with no issues (or spacers). Compare the MP tray to aftermarket tray, you'll see the holes in the aftermarket trays are bigger. Apparently the MP tray holds a little too much oil. I gently pried the openings bigger in the MP tray to make it easier for the oil to make it's way back to the pan.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 340 windage tray on a 360 [Re: flatiron] #587343
01/19/10 10:15 PM
01/19/10 10:15 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
If your question means, will an original 340 windage tray fit on a 360,in my experience.....no. I tried to put a tray from a 70 model 340 onto a 360 motor, and the mount holes weren't wide enough. I had to order one from MP that was a fit-all.
