Code Experts for a 68 Charger.. #586777
01/18/10 07:14 PM
01/18/10 07:14 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
Can someone decode this 68 Charger..I looked at it today and its not a bad car for the money...Hard to tell the paint color..Either burnt orange or copper..Black interior buckets w console automatic 383...No fender tag..And should the core support numbers match like all the rest??
XP29H8B250xxx......
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Code Experts for a 68 Charger.. [Re: 72N96RR] #586778
01/18/10 07:36 PM
01/18/10 07:36 PM
SW Minnesota
Dennis_K Offline
Dennis_K  Offline
SW Minnesota
Not much to go on without a fender tag, but the core support numbers on a 68 do not match the vin, they match the shipping order number which would be on your missing fender tag. With the vin you posted, the number on the core support would read B8X and then the 6 digit SON. The color you described sounds like MM1 Bronze Poly, which was a pretty common color on 68 Chargers.
Re: Code Experts for a 68 Charger.. [Re: Dennis_K] #586779
01/18/10 09:08 PM
01/18/10 09:08 PM
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
Thats good info but what about the dash tag info I posted?? Anyone??
Re: Code Experts for a 68 Charger.. [Re: 72N96RR] #586780
01/18/10 09:16 PM
01/18/10 09:16 PM
In Limbo
Billy B Bad Offline
Billy B Bad  Offline
In Limbo
X = Dodge Charger
P = Premium
29 = 2 Door Sports Hardtop
H = 383 330HP OR 335HP 1-4BBL 8 CYL
8 = 1968
B = Dodge Main, Hamtramck, MI, USA
250xxx = Unknown
Re: Code Experts for a 68 Charger.. [Re: Billy B Bad] #586781
01/18/10 09:34 PM
01/18/10 09:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
all '68 Charger 383 4bbls are of the 330hp variety,
8B250xxx assembled 1st week of January '68
Re: Code Experts for a 68 Charger.. [Re: Dennis_K] #586782
01/18/10 10:38 PM
01/18/10 10:38 PM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
Not much to go on without a fender tag, but the core support numbers on a 68 do not match the vin, they match the shipping order number which would be on your missing fender tag. With the vin you posted, the number on the core support (and trunk lip) would read B8X and then the 6 digit SON. The color you described sounds like MM1 Bronze Poly, which was a pretty common color on 68 Chargers.
The trunk lip stamping (located on the left side under the rubber seal, as you look at the trunk, roughly 1/4 to 1/2 the way up from the bottom) should also match the radiator support stamping.
Dan
