Re: headers in a 66dart what can i use?
[Re: 66dartguy]
#586765
01/18/10 07:43 PM
01/18/10 07:43 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
The passenger side may fit, but the driver's side definitely won't. '63'66 take their own. Thorley makes a set, but they are not cheap.
[Re: slantzilla]
#586766
01/18/10 08:33 PM
01/18/10 08:33 PM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
These are the only under car headers available (tti), others go through the fenderwell. They do interfear with the steering coupler on P.S. cars and the Z-bar some. A few tweeks and your good. Unbeleivable fit, tucks up tight to the floor pan. Takes a special starter and you need to modify the trans crossmember, takes less than 10 minutes.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
