removing wiper arms #586577
01/18/10 04:51 PM
01/18/10 04:51 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
What's the trick to removing wiper arms, from a 65 plymouth b-body ??? The mounting post look's very rusty. I would hate to break them.
Re: removing wiper arms [Re: johnzgarage] #586578
01/18/10 05:04 PM
01/18/10 05:04 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
many people use a screwdriver and pry up and chew the base up, there is a special tool made for the job
Semper Fi
Re: removing wiper arms [Re: johnzgarage] #586579
01/18/10 05:06 PM
01/18/10 05:06 PM
take a soft cloth & fold it several times to reach the right thickness and a large screwdriver or even a jack handle and lever one side carefully/barely until it starts to move off of the threads then move 180 over & repeat til it breaks loose so it comes up/off straight w o cocking and if it has a little lock tab over the bottom side of the threads to keep the arm from coming off of the threaded post move it out 1st before you start levering anything so the arm is free to come off unobstructed
Re: removing wiper arms [Re: RapidRobert] #586580
01/18/10 08:03 PM
01/18/10 08:03 PM
saint paul mn.
saint paul mn.
Thanks....it was a fight..job done.
