Swaping drums to disk, which proportioning valve?
#586415
01/18/10 01:46 PM
01/18/10 01:46 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
I'm in the process of swapping out the from drums on my 72 Duster to a disc setup from a 73 Duster. I'm staying with manual brakes but the 73 proportioning valve was for power brakes. Should I use the existing valve that was on the 72 for manual drums or swap it out to the 73 for power disc? I dont know if theres a different valve for power and manual is why I'm asking, I know the drum and disc is different, so I figured I'd use the one off the 73 with discs, is that correct? Thanks
I also picked up a new style master cylinder from Dr.Diff, that wont make a difference on what I should use, would it? If so I can always use the exsisting proportioning valve and install an adjustable inline valve for the rear?
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Swaping drums to disk, which proportioning valve?
[Re: 440Satellite]
#586416
01/18/10 02:03 PM
01/18/10 02:03 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Drums dont have a PP valve.Use the one from the donor disc setup.I have a 5th Ave PP valve on my manual disc 65 B body.Works perfect.Rocky
Chrysler Firepower
[Re: therocks]
#586417
01/18/10 03:46 PM
01/18/10 03:46 PM
Posts: 6,516 Santa Cruz, California
Lefty
Drums dont have a PP valve. Use the one from the donor disc setup. I have a 5th Ave PP valve on my manual disc 65 B body.Works perfect.Rocky
The combination valve (what you need for disc/drum) does not know if there is a booster or not as it only senses pressure out of the MC, so PB and MB use the same valve.
[Re: Lefty]
#586418
01/18/10 04:02 PM
01/18/10 04:02 PM
440Satellite
super gas
super gas
Hazlet, NJ
Ok, sounds good. Thanks for the info.
Butch
1972 Duster
318 4 speed
