68 GTX Vent Window Removal? #585338
01/17/10 01:24 PM
01/17/10 01:24 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
Im stripping the GTX to go for paint next week and I want to remove the vent window chrome housing. I see in the bottom of the door that the front window track slides over a rod. That seems loose. I also took the nut off the fork in the front and removed the bolt just above it. The question is.... Is there another small bolt through a bracket up high near the mirror. And how the hell do u get it out?
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: 68 GTX Vent Window Removal? [Re: Dr V] #585339
01/17/10 02:00 PM
01/17/10 02:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There's also 2 captive nuts on the door's front upper/outer jamb area, need to open the door, to see them, plus there's up to 3 access holes on the inner panel skin near the A pillar base to access some nuts, IIRC one will be an allen head bolt,...I assume you have removed the main side glass before attempting this?
Mike
Re: 68 GTX Vent Window Removal? [Re: DAYCLONA] #585340
01/17/10 09:22 PM
01/17/10 09:22 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
Thanks. The allen screw was the problem.
1968 Charger 383
2019 Redeye
1979 Branco Red/Red
