When GREEN bearings go bad??
#58521
05/14/08 04:32 PM
05/14/08 04:32 PM
Posts: 1,339 Detroit, Michigan
fjr340gts
Detroit, Michigan
I know that there is always controversy with tapered axle bearings vs. Green Bearings for the 8 3/4. What are the symptoms of Green bearings starting to go bad?? Noise/hummmn in a straight line? More noise when turning in one direction, ot even just doing a lane change?? Are my Greenies going or my Sure Grip?
Re: When GREEN bearings go bad??
[Re: RobR]
#58523
05/14/08 08:18 PM
05/14/08 08:18 PM
fjr340gts
Detroit, Michigan
They really growl..!! I have customers with green brgs that are over 15 years old and still fine...The couple that I've heard that were bad were very noticeable
THANKS! I knew one guy who had his changed every year ~just to play it safe~. Mine have been in for about 4 years. Either way, I guess the axles will have to come out so I can check the bearings regardless. If the bearings are OK, then it means on to the center section.
[Re: fjr340gts]
#58527
05/15/08 07:31 AM
05/15/08 07:31 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
When one of mine when out, it got pretty loud. It growled as described. Drove the car for a lot of miles before I finally fixed it.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: JohnRR]
#58528
05/15/08 07:48 AM
05/15/08 07:48 AM
Posts: 4,884 Michigan
MNobody
frank if you have a cone type and the bearings didn't go bad then you probably lost the sure grip , if it's making noise the spiders are probably siezed on the shaf tand spinning in the case , that will only make noise cornering , straight line it should be quiet as long as your tires are the same height.
Greens and a cone type
John, are you saying that Green bearing's with a Cone type sure grip is a bad thing? Just curious because i've got a 489/cone style and i used green bearing's because some fool took the end play adjuster off my passenger side and i couldn't find a new one. Sorry for hijacking.
[Re: dave571]
#58529
05/15/08 02:35 PM
05/15/08 02:35 PM
fjr340gts
Detroit, Michigan
A check of the end play should tell you alot too.
If there is any, there is a problem.
If there isn't, and the bearing feels smooth, then it's not in the green.
Thanks for the tip. I'll check for end play first. I won't have a chance until next week. B-I-G price difference between a couple new bearings and a center section rebuild................
JohnRR-the SureGrip in the GTS is NOT the cone type.
[Re: fjr340gts]
#58530
05/18/08 08:38 PM
05/18/08 08:38 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
[Re: MNobody]
#58531
05/18/08 08:41 PM
05/18/08 08:41 PM
JohnRR
U.S.S.A.
no not sayingthe 2 together are bad , but i'm scared just thinking about it .
knowing that frank races the car and its a 69 i was thinking it still had a cone type , which i should have known better .
FYI my dart has a cone type it in that i flog , but thats only because i haven't gotten around to swapping it out yet
[Re: JohnRR]
#58532
05/18/08 09:25 PM
05/18/08 09:25 PM
Posts: 8,677 Buford, GA
I_bleed_MOPAR
Buford, GA
Not being familiar with the Green bearings, can you use the old take-the-weight-off-one-side to see if the noise lessens?
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: dave571]
#58533
05/26/08 11:23 PM
05/26/08 11:23 PM
fjr340gts
Detroit, Michigan
CORRECT you are!!! End play on the left side. Which is why it howled whenever I turned right or just changed lanes to the right. Pulled the axles today and will have a new set pressed on tomorrow!!
[Re: da50r]
#58536
10/13/09 08:36 PM
10/13/09 08:36 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I have gone through a couple of sets. My life cycle is short, I went back to taper bearings after I was ready to learn another experiment.
You had to drag up a thread that is a year and a half old for this?
I'm sure there is a more current Green bearing debate that could have been taken part in
[Re: da50r]
#58537
10/13/09 08:40 PM
10/13/09 08:40 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
what type of green bearings are you using? the mopar ones are junk. buy a set from doctor diff, a member here, he sells the better kind.
perception is 90% of reality
[Re: Mr T2U]
#58538
10/13/09 08:57 PM
10/13/09 08:57 PM
Posts: 15,487 Florida
scratchnfotraction
doctor diff mine went 9 yrs then one side went out,growled a lot never noticed it to much thinking it was the cone sg or r&p.. when I noticed smoke behind me on the road,I got to looking,leaked at the bearing and was smoking from it heating up... one side had lots of slop to make both the o-ring and axle tube seal leak..other side tight and most likly did not need replaced..but a pair is a pair in my book.. never got oil on the drum and shoes though replaced both and been back at it hard for a few miles now not running the axle tube seals this go round either,no leaks yet the ones with the crimped on flange are the ones that are junk you want the m-400 that the doc sells,IMHO cant beat the price or the shipping
[Re: dave571]
#58539
10/13/09 10:22 PM
10/13/09 10:22 PM
Posts: 2,628 Middle TN
da50r
Middle TN
Gee whizz, easy there big shooter.. I searched for something else and saw this thread, posted my thoughts... and moved on. I bought the MP bearings FYI. Never had any of dr diffs...
[Re: da50r]
#58540
10/13/09 10:55 PM
10/13/09 10:55 PM
JohnRR
U.S.S.A.
The MP's suck , the DR. Diffs are better , if a green can be better ... unless I'm running a spool or change centers on a bi-weekely basis Greens have no place in a street car . One thing is greens might need a shorter axle so they aren't being sideloded, which they are not designed for, not a problem with a clutch type , leave out the thrust pins , cone type or one legger with a THRUST BLOCK ... different issue .
