Re: 65 B body suspension help.
[Re: Stroked65Belv]
#584590
01/16/10 07:43 PM
01/16/10 07:43 PM
Posts: 6,516 Santa Cruz, California
Lefty
The car in question will be mainly a street cruiser with the occasional run down the 1320. "Would I be best to go with the upgrade to big block bars or something smaller?" I do plan on adding front drag shocks as well as replacing the rear springs with a Caltrac set up.
I would not run 90/10 shocks on a mostly street driven car. I would go with .960" t bars. How about some pics? 65 B body's are cool.
[Re: Stroked65Belv]
#584591
01/16/10 08:04 PM
01/16/10 08:04 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Early B's didn't use a different bar for BB and the A/LA, both used the .860" bar.
[Re: fullmetaljacket]
#584596
01/17/10 01:40 AM
01/17/10 01:40 AM
Posts: 83 Long Island, NY.
Stroked65Belv
Long Island, NY.
Full Metal! great reply! made me laugh a lil here. Its all for the most part a strait shooter! so to speak, yet how far can I drive the geared car that way. I didnt get into the engine aspect though I feel the typical stroker type engines dont need all the gears but for what I want and the tall tire will make me a powerband happy racer on occasion and sadly will still have to trailer my car to Englishtown to run the Mopar Nats in May! Its been my goal since I missed the last one to race there. At least the one run before they shut me down for not having a cage. Glad to see your from Brooklyn. I work in Brownsville and just happen to frequently motivate a large red engine through the streets so I happen to know the power to weight/ratio aspect! Its always fun though... Thanks for the post. Im leaning to just leave the bars and roll with my intentions and hope for what it is. A long island cruiser, and see ya all at Englishtown in May! The thought of LOW LOW 11's would be fantastic!
[Re: 383man]
#584599
01/17/10 08:55 AM
01/17/10 08:55 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Nice 65' Looks to be a Belvedere II ? Also looks like there is a fuel pump/filter hanging out back ? NICE............
I have a 65 as well,,,, i like the side molding delete off the side on yours.......
I put some inexpensive 3 way adjustable shocks on the front of my Charger ( street/strip ),,,and can drop it to 90/10 for racing or other for street use... On the Belvedere i have some QA-1 shocks,,,multi-adjustable,,,,nice shocks,,,but will be trying some Calvert shocks for racing,,, Have Caltracs on the 65',,,
Thanks for posting your car,,,very cool.......
Doug
[Re: 69CHARGERMD]
#584600
01/17/10 09:25 AM
01/17/10 09:25 AM
leave your stock torsion bars in, they will work fine but get yourself a nice set of adju7stable shocks,
#584601
01/17/10 09:26 AM
01/17/10 09:26 AM
stock torsion bars working just fine here!
[Re: Stroked65Belv]
#584603
01/18/10 01:26 AM
01/18/10 01:26 AM
fullmetaljacket
Yeah, We affectionately call it "The Bergen Garage" after the infamous "Woodward Garage" in Detroit by the Chrysler skunk works team. just E-mail me at absolutleestudio@yahoo.com any time in the good weather. We be hanging all over the joint like an ant farm rally. PS: You on the FDNY? Later.
[Re: Stroked65Belv]
#584605
01/18/10 04:47 PM
01/18/10 04:47 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Nice car! I dropped in a 69 B-body K frame and kept the factory bars. That swap moved the engine back about 2 inches and down almost an inch. Out back, I built a knock off of the original Super Stock style springs. It has both front and rear sway bars. The chassis will respond by lifting the rear between 4 and 4-1/2 inches. The front will rise with it. Mine is not a drag car. It's a one-off science project. The stock converter pushing 3.23 gears and 28" tires doesn't make for good 60' times. About 300 feet out the turbos spool and the entire car lifts straight up. If it brakes traction (on the street below 50 mph) the car drops back down until there's some hook again. There's a cheesey youtube video of mine titled hot rod burnout that shows the rear of the car moving around a little bit. You can see it rise with engine torque and drop when I shift to second gear. I wish my car looked as nice as yours. Maybe it will some day. If so, that day is a LONG way off. Here's my toy:
