1964 dodge b body doors #584550
01/16/10 06:19 PM
01/16/10 06:19 PM
N.E. OHIO
P
polara426 Offline OP
P
N.E. OHIO
what do you guys use to replace the cloth insulation on the long door rod inside or should I not worry about it?
Re: 1964 dodge b body doors [Re: polara426] #584551
01/16/10 07:13 PM
01/16/10 07:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's there to keep the rod from rattling. Anything you can sleeve or cover the rod with will work, as long as whatever you use isn't too big in outside diameter.
