Re: B+M SFI flexplate ?
[Re: JohnRR]
#584160
01/16/10 02:25 PM
01/16/10 02:25 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I will say make SURE the convertor holes line up with the convertor bolts. YES, they are assymetrical, but one of my holes on my B&M flexplate was out about 1/16th of an inch, and it was soooooo close but would NOT bolt up. I posted on the forum, got the usual "it only bolts up one way!" responses, but had many chime in their B&M flexplates also had just one hole out, by 1/16th to 1/8th of an inch.... It goes away from the tranny...
CrAzYMoPaRGuY
[Re: hemi-itis]
#584168
01/17/10 12:15 AM
01/17/10 12:15 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
How many of you acutually had someone check the sticker on your flywheel???
Does it matter ? I bought this because a stock one will not fit the convertor that is being used ...
[Re: JohnRR]
#584169
01/17/10 11:48 AM
01/17/10 11:48 AM
Quicktree
[Re: CrAzYMoPaRGuY]
#584170
01/18/10 03:35 PM
01/18/10 03:35 PM
JohnRR
Just checked it and it doesn't line up with more than one hole
[Re: nhramark]
#584172
01/18/10 06:14 PM
01/18/10 06:14 PM
I just bought a brand new B&M plate through Mancini and checked everything before I bolted it up. Fit perfectly.
[Re: CrAzYMoPaRGuY]
#584174
01/19/10 07:43 PM
01/19/10 07:43 PM
Posts: 1,162 s e mich
ro23car
s e mich
Fit perfectly.
MY problem was an eight bolt B&M flexplate with the larger diameter convertor bolts.....
I had it all together, transmission in, and kept fiddling and fiddling, thought my first bolts were too tight, maybe I didn't index it properly, etc etc.... A true pain in the rear.
How much are your holes out?
same problem here b&m flexplate with 8 bolts 1 converter bolt would not fit. had to do some fine tuning on the holes
