B+M SFI flexplate ? #584159
01/16/10 01:19 PM
01/16/10 01:19 PM
A Banana Republic near you.
JohnRR Offline OP
JohnRR  Offline OP
This is the first time I have bought one or frankly ever seen one, it's stamped engine side but it would end up having the offset away from the transmission , is that correct ?
Re: B+M SFI flexplate ? [Re: JohnRR] #584160
01/16/10 02:25 PM
01/16/10 02:25 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I will say make SURE the convertor holes line up with the convertor bolts. YES, they are assymetrical, but one of my holes on my B&M flexplate was out about 1/16th of an inch, and it was soooooo close but would NOT bolt up. I posted on the forum, got the usual "it only bolts up one way!" responses, but had many chime in their B&M flexplates also had just one hole out, by 1/16th to 1/8th of an inch....
It goes away from the tranny...
CrAzYMoPaRGuY
Re: B+M SFI flexplate ? [Re: CrAzYMoPaRGuY] #584161
01/16/10 02:40 PM
01/16/10 02:40 PM
Texas
6packattk Offline
6packattk  Offline
Texas
A trick I learned the hard way of lining converter bolts to flex plate is i sit my convertor snout down in my plastic oil drain pan hole and place flexplate on it and turn it around till all four holes line up and mark flex plate and converter where they line up and will always know where to put it no matter how often or not you remove tranny and verter or engine.And if you are aware of this still might help rookies who don`t.I am old but still a rookie at lots of things.I have round sfi b&m flexplate and it goes on one way.IHTH
Re: B+M SFI flexplate ? [Re: 6packattk] #584162
01/16/10 03:32 PM
01/16/10 03:32 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
Crazymoparguy - I see you have a MP flexplate with the SFI sticker on the wrong side of the plate. I just got one and mine is on the wrong side as well. The sticker is supposed to go on the engine side of the plate so a tech inspector can see if it is out of date without pulling the trany. My old B&M had it on the correct side.
Yes, put the flexplate on the crank so the side that says engine side is facing the engine.
I mark the converter and flexplate by bolting them together before I put them in the car. Then I spray paint one of the the converter lugs and the flexplate. This will make it very easy to reinstall the converter.
Raul
Re: B+M SFI flexplate ? [Re: Aspen7695] #584163
01/16/10 03:37 PM
01/16/10 03:37 PM
Canada
Canada
Raul
That's not my flexplate.
Not my picture!
I just STOLE IT off Google for a picture.... to show in the thread...
(BTW- flexplates with stickers on the wrong side should come with little flex mirrors to throw in your glovebox. It's easier than the tech guy trying to remove your tranny! )
Like I said, above and beyond indexing the holes for the convertor to line it up with the flexplate, beware the 8 bolt B&M flexplates, many had one hole slightly out of whack.
CrAzYMoPaRGuY
Re: B+M SFI flexplate ? [Re: JohnRR] #584164
01/16/10 08:24 PM
01/16/10 08:24 PM
JohnRR Offline OP
JohnRR  Offline OP
I'll have to check it and make sure it fits right now instead of waiting till later .
i did answer my question though , I went an doug out a stock one I have and saw that it indeed does offset toward the engine .
Re: B+M SFI flexplate ? [Re: JohnRR] #584165
01/16/10 10:15 PM
01/16/10 10:15 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How many of you acutually had someone check the sticker on your flywheel???
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: B+M SFI flexplate ? [Re: hemi-itis] #584166
01/16/10 10:34 PM
01/16/10 10:34 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'll keep my mouth shut because as soon as it's open then someone will check mine for the first time in 20+ years
Re: B+M SFI flexplate ? [Re: hemi-itis] #584167
01/16/10 10:42 PM
01/16/10 10:42 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
If you are a class racer and get torn down they sometimes check them. If I am teching a car and there are a lot of questionable items on it I will crawl under and check for things like a driveshaft safety loop and even the sticker on the flexplate.
Raul
Re: B+M SFI flexplate ? [Re: hemi-itis] #584168
01/17/10 12:15 AM
01/17/10 12:15 AM
JohnRR Offline OP
JohnRR  Offline OP
Does it matter ? I bought this because a stock one will not fit the convertor that is being used ...
Re: B+M SFI flexplate ? [Re: JohnRR] #584169
01/17/10 11:48 AM
01/17/10 11:48 AM
Q
Quicktree Offline
Quicktree  Offline
Q
yes it is correct.
Re: B+M SFI flexplate ? [Re: CrAzYMoPaRGuY] #584170
01/18/10 03:35 PM
01/18/10 03:35 PM
JohnRR Offline OP
JohnRR  Offline OP
Just checked it and it doesn't line up with more than one hole
Re: B+M SFI flexplate ? [Re: JohnRR] #584171
01/18/10 04:58 PM
01/18/10 04:58 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I'm pretty sure we drilled the converter holes in my B&M flexplate 1/32" each to make the installation easier.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: B+M SFI flexplate ? [Re: nhramark] #584172
01/18/10 06:14 PM
01/18/10 06:14 PM
I just bought a brand new B&M plate through Mancini and checked everything before I bolted it up.
Fit perfectly.
Re: B+M SFI flexplate ? #584173
01/19/10 07:33 PM
01/19/10 07:33 PM
Canada
Canada
Fit perfectly.
MY problem was an eight bolt B&M flexplate with the larger diameter convertor bolts.....
I had it all together, transmission in, and kept fiddling and fiddling, thought my first bolts were too tight, maybe I didn't index it properly, etc etc....
A true pain in the rear.
How much are your holes out?
CrAzYMoPaRGuY
Re: B+M SFI flexplate ? [Re: CrAzYMoPaRGuY] #584174
01/19/10 07:43 PM
01/19/10 07:43 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
Fit perfectly.
same problem here b&m flexplate with 8 bolts 1 converter bolt would not fit. had to do some fine tuning on the holes
Re: B+M SFI flexplate ? [Re: ro23car] #584175
01/20/10 02:57 AM
01/20/10 02:57 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
So what other SFI flexplate options due you guys suggest?
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: B+M SFI flexplate ? [Re: megajoltman] #584176
01/20/10 03:04 AM
01/20/10 03:04 AM
I use the mopar brand bought from Summit
