Any pinion angle with ladder bars? #583253
01/15/10 12:03 PM
01/15/10 12:03 PM
Duncan, BC... or Lakehead, Ca.
440Dave Offline OP
440Dave  Offline OP
I've been racing my leaf sprung cuda for years and never paid much attention to ladder bar equipped cars(they were always behind me, haha) but now I'm getting ready to install the rearend in my Henry J and its got coil springs and ladder bars. I'm assuming that since the ladder bars allow no axle rotaton, there should be little or no pinion angle. What is correct?
Re: Any pinion angle with ladder bars? [Re: 440Dave] #583254
01/15/10 12:06 PM
01/15/10 12:06 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
2-3 degrees down from center line of trans.
Re: Any pinion angle with ladder bars? [Re: mopartony] #583255
01/15/10 12:11 PM
01/15/10 12:11 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
2 degrees negative of the driveshaft angle.
Re: Any pinion angle with ladder bars? [Re: B G Racing] #583256
01/15/10 12:14 PM
01/15/10 12:14 PM
440Dave Offline OP
440Dave  Offline OP
That makes sense, as I guess there will still be some movement even when solid mounted. Should I mount the engine and tranny to give 2 degrees positive at the other end?
Re: Any pinion angle with ladder bars? [Re: 440Dave] #583257
01/15/10 01:13 PM
01/15/10 01:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That makes sense, as I guess there will still be some movement even when solid mounted. Should I mount the engine and tranny to give 2 degrees positive at the other end? [/quot
The more inline you can mount the driveline the better ie: crank,tranny out put shaft and pinion centerline,keeping the u-joints well within their working ranges.Ideally if everything was inline but since some rearend pinion centers are lower than the crank and tranny centerline and some higher(depending on the ride height) you must make the adjustments.Even if you build the drivetrain inline the moment you change the ride height or instant center you have to re-adjust pinion angle.
Re: Any pinion angle with ladder bars? [Re: B G Racing] #583258
01/15/10 01:17 PM
01/15/10 01:17 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
That is exactly how we set them up.
Jeff
Re: Any pinion angle with ladder bars? [Re: JERICOGTX] #583259
01/15/10 01:29 PM
01/15/10 01:29 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Jeff
Where's Quicktree?He must still be jacking Wedgie.He's missing this angle.
Re: Any pinion angle with ladder bars? [Re: B G Racing] #583260
01/15/10 01:46 PM
01/15/10 01:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Jeff
no I seen it no use you can't teach an old ugly dog new tricks
Re: Any pinion angle with ladder bars? [Re: B G Racing] #583261
01/15/10 01:50 PM
01/15/10 01:50 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Jeff
Mopar Performance
