Re: Any pinion angle with ladder bars?
[Re: 440Dave]
#583257
01/15/10 01:13 PM
01/15/10 01:13 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
That makes sense, as I guess there will still be some movement even when solid mounted. Should I mount the engine and tranny to give 2 degrees positive at the other end? [/quot
The more inline you can mount the driveline the better ie: crank,tranny out put shaft and pinion centerline,keeping the u-joints well within their working ranges.Ideally if everything was inline but since some rearend pinion centers are lower than the crank and tranny centerline and some higher(depending on the ride height) you must make the adjustments.Even if you build the drivetrain inline the moment you change the ride height or instant center you have to re-adjust pinion angle.
[Re: B G Racing]
#583258
01/15/10 01:17 PM
01/15/10 01:17 PM
Posts: 10,020 MN
JERICOGTX
MN
2 degrees negative of the driveshaft angle.
That is exactly how we set them up.
Jeff
[Re: JERICOGTX]
#583259
01/15/10 01:29 PM
01/15/10 01:29 PM
B G Racing
Eighty Four, PA
Jeff
Where's Quicktree?He must still be jacking Wedgie.He's missing this angle.
[Re: B G Racing]
#583260
01/15/10 01:46 PM
01/15/10 01:46 PM
Quicktree
Jeff
no I seen it no use you can't teach an old ugly dog new tricks
