How to tell an original 340 cam from repro? #583176
01/15/10 10:27 AM
01/15/10 10:27 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I have a cam that I took out of my 1971 Challenger 340. I measured the lift at valve before I removed it, and it was right at spec, at .429/.444. So this cam is eather an original or repro. The only I.D. on this cam is as follows.
1) Between the first journal and the first lobe, there is some green paint and two sets of numbers.
One set is raised and is 1138. The other is embedded and says 1136.
2)Between the last journal and the distributor gear are two embedded numbers. One says D1 and the other says C1
Can anyone tell the difference between the original and repro? Thanks.
Re: How to tell an original 340 cam from repro? [Re: ragtop] #583177
01/15/10 08:33 PM
01/15/10 08:33 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Anyone? Thanks.
Re: How to tell an original 340 cam from repro? [Re: ragtop] #583178
01/15/10 10:39 PM
01/15/10 10:39 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Anyone? Thanks.
What difference would it make?
Re: How to tell an original 340 cam from repro? [Re: I go fast] #583179
01/15/10 11:29 PM
01/15/10 11:29 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Does it matter?
Besides that, a cam grinder will tell you that unless you have the lifters that were used on it before, in the right order, it's garbage now. New lifters will wipe the lobes off.
Also, due to differences in lifter bore align etc, it really only should be used in the 340 it came out of, even if you still had the lifters in the right order..
In the old days(when oil was still decent) you could get away with a lot in the area of cam swap. These days, it goes to heck in a hurry.
