My Curiousity Is Killing Me...Make Some HP/TQ Guesses.. #58276
05/12/08 01:32 AM
05/12/08 01:32 AM
Sorrento, BC, Canada
4speeds4me Offline OP
So reading this 425HP 360 thread:
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
I keep wondering what this 360 I'm putting together might be capable of. So here's the specs. What do you guys think?
360 +.030"
KB107's
.040" quench
10.6:1 CR
Edelbrock LA Heads.
Cam is 288º (254º @ .050") .525" solid on a 112º LSA
M1 Single Plane w/800cfm Thunder Series carb
What do you guys think it should be capable of laying down for numbers?
Thanks for the look and the guesses...
2 Demons...no, not my kids!
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guesses.. [Re: 4speeds4me] #58277
05/12/08 07:08 AM
05/12/08 07:08 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It all depends on the machining. Done by what I consider right, I'd be looking for just over 400hp from it. Some of the guesses on that post IMO are very "happy". You have a stout package there, but the cam is a medium size. Go0od for your build, ad strong on mid range. But might fall a litle short n the hp side if your goal is 430. And if the machining isn't spot on and complete, I would expect the numbers to hover around 390-400. Still plenty stout.
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guesses.. [Re: 4speeds4me] #58278
05/12/08 12:17 PM
05/12/08 12:17 PM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
You should definately be able to get 400 with that combo. How far above depends on any head work that gets done and its quality
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guesses.. [Re: DemonKyle] #58279
05/12/08 02:38 PM
05/12/08 02:38 PM
I do find it interesting that 400 out of a 318 w/KB167's and BOX STOCK Magnum heads and flat tappet cam is so easy to achieve, but this combo is barely worth 400? Not that I'm disbelieving your opinions, but that 400HP 318 was a VERY basic build, and from what I recall the Eddy heads for the LA still put out better flow numbers than bone stock Mags.
Keep 'em coming though. I am interested to hear what else is out there...
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guesses.. [Re: 4speeds4me] #58280
05/12/08 09:56 PM
05/12/08 09:56 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
offload the single plane and get an Air-gap.
400-425 is a potent 360 for the street - be satisfied - build it and rubber will roll.
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guesses.. [Re: JUST_N_TIME] #58281
05/12/08 10:52 PM
05/12/08 10:52 PM
While I agree with you on the intake, I have 2 choices as I have to run what I have. I can use the M1 (which I have) or a 1968 factory 340 intake (which I have). I think the M1 will hurt the package less.
FWIW, at least there's a stick going in behind it!
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: 4speeds4me] #58282
05/16/08 12:28 AM
05/16/08 12:28 AM
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
The reason I say 400 is because my combo is pretty much the same as yours except for: smaller cam, stock heads and ld340 and I'm making 350 at the flywheel
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: 4speeds4me] #58283
05/16/08 08:53 AM
05/16/08 08:53 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I think Magazine hp and real world hp are to different things. hp #s sell magazines.
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: AdamR] #58284
05/16/08 12:09 PM
05/16/08 12:09 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
most of Dulcich's stuff is done at Westech, which judging the numbers might be a slightly optimistic dyno, but I'd say you should be able to compare different motors from that dyno. Looking at the MM engine challenge power results, Comp Cam's dyno looks to be extra stingy (considering a 318 with ported enginequest heads and a solid cam only made ~380HP, and 400+" combos with ported eddies made less than 470 HP)
and unfortunately, we have no correlation between those HP numbers from those dynos and using the moroso power calculator trap speeds & weight, like Ryan J has with Ryder's dyno.
comparing dulcich's 400HP 318 to the 448 HP 360 in the other thread, and then comparing it to yours, I'd say a solid flat tappet vs. juice roller is going to be pretty much a wash, you have about 1 point more compression, better quench, but what I've seen of published OOTB numbers, the eddie mags flow slightly better, so I'd say all in all, it should perform similarly to the 448 HP 360 Dulcich did. Will it make 450 on every dyno? probably not. I'd guess the combo you have listed would easily get an A body into the 12's...
2017 Grand Cherokee Overland
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: patrick] #58285
05/16/08 12:30 PM
05/16/08 12:30 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
i agree about the air gap happiness.
id say your close to the rpm 360 combo, and make close to the # they did. 400-420hp.
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: mark7171] #58286
05/16/08 04:56 PM
05/16/08 04:56 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Looks good overall but I'm not wild about a single plane manifold 112 centerline cam combination on a 360....although a 112 can be a good choice for a stick car (judging by your name and avatar) unless the car is really light it can cost you some ET so you might consider either tightening the lobe spread OR going to a big dual plane manifold. The reason is a single can cost you a bit of torque pound-feet right at the shift recovery RPM unless you've got excellent heads and you're winding it up pretty tight.
Wize's
Your results may vary!
WIZE
In Car:
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: Streetwize] #58287
05/16/08 11:33 PM
05/16/08 11:33 PM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
couldn't have said it better. Why is it you can't get an air gap on there?
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: enelson] #58288
05/19/08 07:43 PM
05/19/08 07:43 PM
Budget. I HAVE the M1...I'd have to buy the Airgap. I haven't ruled it out for a later date....just not right now...
And yes, it'll have a stick. Looking at the MPH/rpm numbers with my ratios in one calculator, shift recovery should not be too bad...
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: 4speeds4me] #58289
05/19/08 10:31 PM
05/19/08 10:31 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i see a flaw in your plan Dan, you have picked a engine with the distributor in the wrong end of the engine.
turning the engine around will not fix your problem.
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: chrisf] #58290
05/20/08 02:34 AM
05/20/08 02:34 AM
Oh, ye of little faith! Actually, I'm turning it around AND tipping it a bit to one side!
Re: My Curiousity Is Killing Me...Make Some HP/TQ Guess [Re: 4speeds4me] #58291
05/21/08 09:07 AM
05/21/08 09:07 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I would use a plane RPM intake over the AirGap. Same runners, same height less expensive.
