Re: Water base auto paint
[Re: NortheastMopar]
#581983
01/14/10 08:45 AM
01/14/10 08:45 AM
Posts: 1,064 Washington
69440
Washington
I've used the water based paint by Matrix. Sprayed very well and flowed out even better, but the clear coat is a whole different ballgame. Be sure and use an ample amount, cause I found it's a lot easier to burn through than with the acrylic based paints. It's yet to be seen how long the shine will hold up as it's only been done for a couple of months. All in all, I'd use it again. Another great thing is that the yard natzee's can't shut you down for sprayin in your own shop,,,,,,,,,,YET!!!!!
[Re: 69440]
#581984
01/14/10 09:25 AM
01/14/10 09:25 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
i use PPG water based base coat at work. you can't use this stuff at home without really good equipment. especially your air compressor. you have to dry it about 1% humidity. the air dryer to do that is about $800. when using the hand held air dryers i can make the stuff dry FASTER than solvent based paint. on larger jobs without using the hand held air dryers it drys as fast as solvent based paint. one thing to keep in mind you MUST surface prep the panel much better than for solvent based job. this is because water based paint is much thinner than solvent paint. also you can't mix solvent and water based paint waste. YES water based paint is a hazardous product, and MUST be treated as such. hope this helps i spray solvent based clear coat on top of water based base coat.
perception is 90% of reality
[Re: 6pkaar]
#581992
01/18/10 03:10 PM
01/18/10 03:10 PM
Posts: 8,914 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
FWIW I have a friend who does loads of small stuff - helmets, guitars, etc. in his backyard shop in ALL kinds of weather. This is not a bodyshop or spraybooth, just a regular ol' garage. He uses AutoAir Colors products. I don't understand what the big concerns are. From what I've read the coats have to be very light or the product will run/sag. The moisture should evaporate under normal temps, humidity and airflow conditions in reasonable amounts of time. Environmental impact would be more from the pigments than from the water. http://www.autoaircolors.com/index.htm
[Re: Stanton]
#581993
01/18/10 04:31 PM
01/18/10 04:31 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I agree that it sounds like a horrible idea for automotive paints, because it's new and we don't know how to use it yet, but if they have water based exterior paints for houses that last 15 years when exposed all the time, surely it wouldn't be too difficult to add some sort of catalyst to make the paint harden so you can sand and buff it, and use it on metal. even if it only ends up lasting 10 years--that's still longer than the average life of your typical daily driver--my big block dakota is just over 10 years old, and the factory clear coat, solvent based paint is starting to lift already...
if you put it on a hotrod toy vehicle that's garage kept, that "10 year paint" will probably last a LOT longer.
I wouldn't be afraid of this stuff, but it's awfully new, so I'll be waiting until it's been around for a few years before I'd consider using it on my rides
**Photobucket sucks**
[Re: 70Cuda383]
#581994
01/18/10 05:47 PM
01/18/10 05:47 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Really ?!?!?! Why ???? No harmful solvents, less environmental impact, easy cleanup ... what's "horrible" about it ?
It still gets clearcoated with standard solvent-based clears and that's where the durability is. The water-based product is just the color - nothing more.
[Re: Stanton]
#581995
01/18/10 05:48 PM
01/18/10 05:48 PM
DaytonaTurbo
Manitoba, Canada
What about single stage paints?
[Re: DaytonaTurbo]
#581997
01/18/10 08:27 PM
01/18/10 08:27 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Yeah, I got some downstairs in the basement ... Sherwin-Williams outdoor acrylic latex. Comes in flat, semi-gloss or gloss. Apply with brush or roller. For use on wood or primered metal. Available at Home Depot for $25 a gallon !!
