Rolling a bead into copper pipe #581388
01/13/10 06:55 PM
01/13/10 06:55 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
I've got a '68 Sweptline and I'm replacing the heater control valve and the heater core. The control valves aren't made any more. I have to use a generic control valve and add a tube to it to go through the firewall. The stock tubes have a lip rolled into the pipe.
I've been to machine shops, old school car shops, and radiator shops and no one seems to have the equipment to roll the bead into the copper pipe to make it like stock.
I know that:
1) Eastwood sells equipment to do this but I ain't spending $600 to roll two beads
2) I could just flare it.
I want this to be as original as possible but if I cannot find someone that can roll the bead in then I will just flare it.
If there is a shop or person in the Atlanta area, heck, a shop or person within a 200 mile radius of Atlanta that can do this, let me know.
Here's what the stock end looks like:
Re: Rolling a bead into copper pipe [Re: Chilort] #581389
01/13/10 07:13 PM
01/13/10 07:13 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Try an air conditioning fab shop maybe ?
Re: Rolling a bead into copper pipe [Re: Chilort] #581390
01/13/10 07:59 PM
01/13/10 07:59 PM
A slight flare of just the right amount & it will not leak and it would be hidden if you could live w that
Re: Rolling a bead into copper pipe [Re: RapidRobert] #581391
01/13/10 08:23 PM
01/13/10 08:23 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I can live with the flare. If I cannot find anything by about this time next week, then that's what is going to happen.
Most A/C shops and plumbers these days just sweat pipe. At least the ones I've talked to.
Re: Rolling a bead into copper pipe [Re: Chilort] #581392
01/13/10 08:31 PM
01/13/10 08:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You can buy the individual tubing beaders from Aircraft Spruce for $50-60.
http://www.aircraftspruce.com/search/search.php
Re: Rolling a bead into copper pipe [Re: Chilort] #581393
01/13/10 08:34 PM
01/13/10 08:34 PM
yeah I wanted to roll a bead on some tubing pieces to fab some custom radiator hose routing and Eastwoods price stopped me dead in my tracks . I hear their stuff is top notch but like you I'd only be rolling several beads.
Re: Rolling a bead into copper pipe [Re: John_Kunkel] #581394
01/13/10 08:42 PM
01/13/10 08:42 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Is this what you are talking about?
http://www.aircraftspruce.com/catalog/topages/ezbeader.php
How does it work?
If that's it, I'll buy that tool!
Re: Rolling a bead into copper pipe [Re: Chilort] #581395
01/13/10 08:48 PM
01/13/10 08:48 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
John, I owe you one!
I found some info on the interwebs. Fantastic!
Re: Rolling a bead into copper pipe [Re: Chilort] #581396
01/13/10 09:09 PM
01/13/10 09:09 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Cool tool!
Re: Rolling a bead into copper pipe [Re: OzHemi] #581397
01/13/10 09:17 PM
01/13/10 09:17 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Are you going to leave it exposed? 'Cause if not, who the hell's going to know it doesn't have a bead ?!?!?
Re: Rolling a bead into copper pipe [Re: Stanton] #581398
01/13/10 09:37 PM
01/13/10 09:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The bead helps retain the hose against the clamp, and keeps it from "creeping" under pressure, which would result in a "blown" hose down the road eventually if there's no bead to offer resistance,...if it wasn't needed, manufacturers wouldn't waste their time forming it, like the Sun, it's there for a reason
Re: Rolling a bead into copper pipe [Re: DAYCLONA] #581399
01/13/10 09:48 PM
01/13/10 09:48 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
If this were under the hood, I likely wouldn't care. But some of these connections are in the heater box. While not a PITA to pull, it isn't exactly fun just to fix a slipped hose. Plus, they sell these at Summit, I live near a Summit outlet and I have a Summit coupon right now that covers nearly half the price.
Oh, and it is easier to do a job right the first time than to do it over. Though the amount of time trying to find this tool nearly broke that rule.
Re: Rolling a bead into copper pipe [Re: Chilort] #581400
01/13/10 10:02 PM
01/13/10 10:02 PM
Ohio
W
wedgg440 Offline
wedgg440  Offline
W
Ohio
Another way to accomplish what your trying to do is to see if you can find a brass ferrule to fit your tubing and just solder it on the tube.
Re: Rolling a bead into copper pipe [Re: wedgg440] #581401
01/13/10 10:16 PM
01/13/10 10:16 PM
scratchnfotraction Offline
thats a good idea
old mopar man must have been around the block a time or two and been there done that
hardware store in the plumbing section for a ferrule that size
Re: Rolling a bead into copper pipe [Re: RapidRobert] #581402
01/13/10 10:53 PM
01/13/10 10:53 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Eastwoods price stopped me dead in my tracks . I hear their stuff is top notch...
HA!! I bought one of their bead rollers once. When it arrived it was the same one my friend had from Harbor Freight!!!
Re: Rolling a bead into copper pipe [Re: wedgg440] #581403
01/13/10 11:22 PM
01/13/10 11:22 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I can find a ferrule that size. It is something a few people recommended. ... it would be cheaper. A pack of two ferrules was about $2.50. I've already got the propane torch and solder.
Re: Rolling a bead into copper pipe [Re: Chilort] #581404
01/14/10 12:58 AM
01/14/10 12:58 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Forget the ferule ... get a short piece of household copper wire (14 gauge) and make yourself a ring and solder it to the pipe. Shouldn't take more than 2 inches.
Re: Rolling a bead into copper pipe [Re: Chilort] #581405
01/14/10 03:48 AM
01/14/10 03:48 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Ferrule is what I had in mind. The copper ring would be great if OD of tubing isn't an aval. ferrule size.
Re: Rolling a bead into copper pipe [Re: PhillyRag] #581406
01/14/10 06:19 AM
01/14/10 06:19 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
How's this 'ghetto' way of "getting 'r done"...?
Meet, the GhettoBeader...!
Re: Rolling a bead into copper pipe [Re: PhillyRag] #581407
01/14/10 08:57 AM
01/14/10 08:57 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I considered going this route but at the two hardware stores I went into (big box type) I couldn't find unions that had free ferrules. All of the ferrules were captured in the compression nut.
I love Ghettobeader.
