Crankshaft balancing 500" 440 stroker question???? #581294
01/13/10 12:47 PM
01/13/10 12:47 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Hello,
I am beginning a 440 stroker build. I'm going to use 440Source for the kit. Has anybody had bad luck with this company?
Also, what is the recommended method for balancing the crank; with or without the harmonic balancer and flex plate?
Regards
Re: Crankshaft balancing 500" 440 stroker question???? [Re: kz5rt2] #581295
01/13/10 01:16 PM
01/13/10 01:16 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The rotating assembly should be neutral balanced , as should be your dampner and and flexplate , I would have the dampner and flexplate checked separately and corrected if needed. On a neutral balance rotating assembly you shouldn't need to have those parts installed .
Re: Crankshaft balancing 500" 440 stroker question???? [Re: JohnRR] #581296
01/13/10 02:12 PM
01/13/10 02:12 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Leave the gun.......take the Cannoli's....Mike
Re: Crankshaft balancing 500" 440 stroker question???? [Re: kz5rt2] #581297
01/13/10 07:45 PM
01/13/10 07:45 PM
AndyF Online content
AndyF  Online Content
Looks like you are in Detroit so there are lots of machine shops in the area that can handle the engine build for you including the balance work. Best bet is to go sit down with someone at the engine shop before you buy too many parts and see what they have to say.
