ouch!
![](/ubbthreads/images/graemlins/shock.gif)
just tighten it up till you cant any more and let it buck
seems like thee should be a hole for the cottor pin in all of the tie rods and pitman/drag links
I would be drillin one if there is room,I have done lost a tie rod while driving at 55 mph
had a ball joint fall out on a 96 ram 1500 at about 75mph..didnt get to save that one,whole spindle tire ripped off and took out the fender and door be for the ditch
![](/ubbthreads/images/graemlins/whistling.gif)
check header clearance when its sitting on the ground at ride hieght
![](/ubbthreads/images/graemlins/scope.gif)
how you like those headers now???
![](/ubbthreads/images/graemlins/laugh2.gif)
