Throttle cable bracket for Indy Max wedge manifold #580112
01/12/10 12:11 AM
01/12/10 12:11 AM
VT
MOPARCRAZY Offline OP
VT
I am changing to the Indy max wedge manifold (440-2) The adjustable bracket I used before doesn't clear. What bracket fits the Indy?
Thanks for any help.
Re: Throttle cable bracket for Indy Max wedge manifold [Re: MOPARCRAZY] #580113
01/12/10 12:16 AM
01/12/10 12:16 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
had the same problem so i made one that mounts onto the carb studs. now it fits any manifold.
Re: Throttle cable bracket for Indy Max wedge manifold [Re: MOPARCRAZY] #580114
01/12/10 01:53 AM
01/12/10 01:53 AM
AndyF Offline
AndyF  Offline
The brackets I make work with that intake. There is also a matching throttle return with dual springs. Mancini, Hughes, Magnum HP, Mayo Performance, etc all carry these brackets.
Re: Throttle cable bracket for Indy Max wedge manifold [Re: AndyF] #580115
01/14/10 02:09 AM
01/14/10 02:09 AM
VT
VT
Thanks for the help!
