What comp height for 360? #580013
01/11/10 10:55 PM
01/11/10 10:55 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
What compression height do I need for a 77 model 360 in order to get the piston as close to the top as possible and how far down will they be on a untouched block, im looking at flattops. Anyone have any ideas?
Re: What comp height for 360? [Re: 68gtxsurvivor] #580014
01/11/10 11:10 PM
01/11/10 11:10 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I think the Keith Black KB107 is 1.675"
It's probably one of the tallest shelf pistons for the 360.
One of the least expensive too.
Re: What comp height for 360? [Re: S/ST 3040] #580015
01/12/10 10:39 AM
01/12/10 10:39 AM
The Great White North
RAMM Offline
RAMM  Offline
Vic is right just read what KB says about the required top ring gap. Or if you're not into that you can use Sealed Power H116cp they are a nice piston very similar to the KB- they have a 1.660" comp height and feature coated skirts FWIW and you don't have to gap the rings in any special way. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
