727 Auto Trans Questions; Plastic shavings/sealing pan #579899
01/11/10 08:17 PM
01/11/10 08:17 PM
ND
Birdlover Offline OP
ND
Today I took the pan off my '69 RR just because the gasket was leaking. I found the oil to be clean and in good color but found small plastic white shavings at the bottom of the pan. The trans was not having any operational issues. Where are these shavings from and are they anything to be concerned about?
I bought one of the hard plastic gaskets with the small o-rings around the perimeter. However, no matter how hard I tried (with very careful pounding), I could not get the old stamped metal pan true and flat. I am sure it will leak again even with the new gasket. Anyone have a suggested source for a new straight pan?
1969 Road Runner, B7 Blue, 383, Auto
Re: 727 Auto Trans Questions; Plastic shavings/sealing pan [Re: Birdlover] #579900
01/11/10 08:39 PM
01/11/10 08:39 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i had same leak isuse,bought new pan from summit,can't remeber the name,but it had cooling tubes built into the bottom,added 2 qts extra,and a magnetic drain plug,i think it was around 100.00,drain plug ,never know why they didn't all have them,makes an unpleasant job,nice
Re: 727 Auto Trans Questions; Plastic shavings/sealing pan [Re: meepmeep70] #579901
01/11/10 08:52 PM
01/11/10 08:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Probably some one had a problem with a speedo gear.
Re: 727 Auto Trans Questions; Plastic shavings/sealing pan [Re: Birdlover] #579902
01/11/10 08:56 PM
01/11/10 08:56 PM
ND
ND
I saw the aluminum pans in Summit but didn't really want to spend that much or lower my ground clearance by the additional 2 qts. Anyone still sell steel stamped pans or aluminum ones in stock capacity? Thanks!!
Re: 727 Auto Trans Questions; Plastic shavings/sealing pan [Re: Birdlover] #579903
01/12/10 07:27 AM
01/12/10 07:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I haven't seen a source for a NEW stock pan other than MAYBE the dealer .
Re: 727 Auto Trans Questions; Plastic shavings/sealing pan [Re: Birdlover] #579904
01/12/10 07:48 AM
01/12/10 07:48 AM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
the trans pan on my 99 durango (LOOKS) like it would fit a 727, thought i read or was told that it is a 727 with updated tech, this pan is a little deeper than the old stock ones but maybe not as deep as the after markets, im sure someone will chime in and correct me if i'm wrong, that would be ok, i would like to know for sure, kinda sounds like a hijack huh.
Re: 727 Auto Trans Questions; Plastic shavings/sealing pan [Re: Lew] #579905
01/12/10 09:09 AM
01/12/10 09:09 AM
scratchnfotraction Offline
yes IIRC the new pans from a 96 1500 will fit
I bet that the improved pan gasket you got will work
just need to not over tighten the bolts and strip them out
just make sure your pan is not dimpled around the bolt hole and try it,IMO
my pan was beat and seald it right up,have had it off a few times and reused the same gasket
summet jegs hughes CRT local tranz shop dealer all should be able to get you one
the chrome holds heat and does not seal with out scuffing the pan rail
get a plane steel or alum
summit has some nice alum ones with or with out the logo
CRT are real nice alunyum
