What block is this? Is it a pre-World block? How much can it be bored to, and is it a 4 bolt main block? Thanks Jamey
Mopar Performance 440 Wedge & Hemi Blocks
Item# newitem92935559
.Product Description
We have a limited supply of the hard to get Mopar Wedge & Hemi blocks. Please call on availability @ 800-843-2821
440 Wedge Cast Iron Block
Wedge blocks feature factory size bores, water flow between the cylinders for improved cooling and sealing durability. These blocks are fully water-jacketed.
$2,650.00
MOPP5007815CL
