carb spacer #579662
01/11/10 04:38 PM
01/11/10 04:38 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
how much does a carb spacer help?right now my carb is just mounted on the man.i tried a 2in. but my hood doesnt fit.if its really worth a try i think a 1in. will fit.
Re: carb spacer [Re: bonefish] #579663
01/11/10 04:48 PM
01/11/10 04:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Depends on the combo; my drag-motor SB picked up 8 HP & about the same ft/lbs with a 4-hole 2" spacer. Didn't pick up as much with a 2" open, and 1" either open or 4-hole had almost no gain.
Like so many things, you have to experiment.
Re: carb spacer [Re: topside] #579664
01/11/10 06:00 PM
01/11/10 06:00 PM
Locomotion Offline
Locomotion  Offline
.....experiment not only with different spacers, but it can also affect the carb setting. In other words, what may be "optimum" for the carb with no spacer may require jet and/or squirter & pump cam changes to optimize it to the spacer, or different spacer.
(i.e.: If your carb set-up is "correct" and you install an open spacer, you may have a bog and/or A/F ratio may be leaned out a bit due to the bigger plenum volume.)
Re: carb spacer [Re: bonefish] #579665
01/11/10 06:13 PM
01/11/10 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you a foot brake or trans brake... a 4 hole will
usually help the low end response and the open will
usually help in high rpm.... IF you need the added
plenum volume
Re: carb spacer [Re: MR_P_BODY] #579666
01/11/10 07:05 PM
01/11/10 07:05 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
im just foot braken now,i guess ill just have to try a 1in, and see how it does,Thanks
