Page 1 of 4 1 2 3 4
Biggest street tire under a 1969 B-Body??? #578610
01/10/10 03:26 PM
01/10/10 03:26 PM
Boise, Idaho, U.S.A.
tims69belvedere Offline OP
I was wondering what is the biggest street tire to get under my 69 B-body? Thanks in advance
Re: Biggest street tire under a 1969 B-Body??? [Re: tims69belvedere] #578611
01/10/10 03:27 PM
01/10/10 03:27 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
stock ???
Mopar Performance
Re: Biggest street tire under a 1969 B-Body??? [Re: moparniac] #578612
01/10/10 03:28 PM
01/10/10 03:28 PM
Its got a stock 83/4 under it.
Re: Biggest street tire under a 1969 B-Body??? [Re: tims69belvedere] #578613
01/10/10 03:31 PM
01/10/10 03:31 PM
Milford, IL
68Plymouths Offline
68Plymouths  Offline
Milford, IL
I have 295-50-15's under my satellite. Just enough room. I think a 305 would be pretty tight.
Re: Biggest street tire under a 1969 B-Body??? [Re: 68Plymouths] #578614
01/10/10 03:38 PM
01/10/10 03:38 PM
Pics??
Re: Biggest street tire under a 1969 B-Body??? [Re: tims69belvedere] #578615
01/10/10 06:31 PM
01/10/10 06:31 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I currently have p285/70r15 bfg radial t/a under 69 road runner.Bfg discontinued them,but you can get them from Coker Tire (800)251-6336
I have them with 15x8 road wheels,8-3/4,regular shocks, and no wheel lip edges have been rolled. Car looks stuffed with them on.
Sorry,don't know how to resize a pic.
Re: Biggest street tire under a 1969 B-Body??? [Re: jcastle1] #578616
01/30/10 11:35 PM
01/30/10 11:35 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Anyone running something different?
Re: Biggest street tire under a 1969 B-Body??? [Re: jcastle1] #578617
01/31/10 12:06 AM
01/31/10 12:06 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
295/65/15 is what i run on the Charger
Re: Biggest street tire under a 1969 B-Body??? [Re: 69CHARGERMD] #578618
01/31/10 12:11 AM
01/31/10 12:11 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
315/60-15 on my 68 (M/T ET Street Radial) will rub a bit on the inside when you turn sharp due to no swaybars. stock dana 60 with 15x10 with 5 inch backspace
Re: Biggest street tire under a 1969 B-Body??? [Re: prochargedhemi] #578619
01/31/10 02:07 AM
01/31/10 02:07 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
On my 69 coronet before I relocated the springs I ran a weld prostar 15/4.5 back space with a 30/12.5/15 MT ET Street
it was tite but it worked really good, barely rubed the leaf springs.
Re: Biggest street tire under a 1969 B-Body??? [Re: RockChip] #578620
01/31/10 02:45 AM
01/31/10 02:45 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
325-50-15 et radials under my 68 gtx with the wheel lips rolled.
Re: Biggest street tire under a 1969 B-Body??? [Re: SCATPK] #578621
01/31/10 02:47 AM
01/31/10 02:47 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
under car shot.
Re: Biggest street tire under a 1969 B-Body??? [Re: SCATPK] #578622
02/26/10 12:35 PM
02/26/10 12:35 PM
IL
knyech1 Offline
knyech1  Offline
IL
My dad has a 68 'net and he wants to put a 265/60-R15 on an aftermarket wheel. Would 4-1/2" backspace do the trick?? I think the wheels he has picked out have 3-1/2 and I don't want him to order unless he knows for sure but he is getting ancy.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Biggest street tire under a 1969 B-Body??? [Re: knyech1] #578623
02/26/10 12:51 PM
02/26/10 12:51 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
325/50/15 on my car with a 4.75" back space rim, 4.5" would work also
Re: Biggest street tire under a 1969 B-Body??? [Re: tims69belvedere] #578624
02/26/10 03:04 PM
02/26/10 03:04 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Correct me if I'm wrong but Dodges have larger openings and have room for bigger tires. Compare any '66-'70 Dodge and the same year Plymouth and you'll see it.
Re: Biggest street tire under a 1969 B-Body??? [Re: 52savoy] #578625
02/26/10 04:04 PM
02/26/10 04:04 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
I have a 69 Sport Satellite with MT 295/65r15's on 8" rims
With 4.5" back space. I have about 1/3" between the spring
And fender. It's tight but has never rubbed.
Re: Biggest street tire under a 1969 B-Body??? [Re: Big B] #578626
02/26/10 04:29 PM
02/26/10 04:29 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
My uncle has 14.5x28 QTP's on his 68 RR with a 8 3/4 rear. Not sure of the bs on the rims.
Re: Biggest street tire under a 1969 B-Body??? [Re: MIKES_DUSTER] #578627
06/25/10 01:05 PM
06/25/10 01:05 PM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
Getting ready to order a set of tires and wheels. Anyone think a 275/60R15 BFG Drag Radial is going to look too small on a 10" rim?
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: Biggest street tire under a 1969 B-Body??? [Re: 68 Roadrunner] #578628
06/25/10 02:37 PM
06/25/10 02:37 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
In my opinion,they will look too small! I tried out a set of p275-60's a while back,and HATED the look! I'm with Doctor Doug! P295/65R-15'S! Look just right! RandyB
Re: Biggest street tire under a 1969 B-Body??? [Re: Labratt] #578629
06/25/10 02:44 PM
06/25/10 02:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
had 11.5x29.5 under my 69 RR with a little lip trimming.
Page 1 of 4 1 2 3 4
