Piston to wall clearence #578516
01/10/10 01:17 PM
01/10/10 01:17 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
When it's stated that you should have say .004 piston to wall clearence do they mean .002 on each side of the piston or do they mean .004 on each side?
Re: Piston to wall clearence [Re: flatiron] #578517
01/10/10 01:23 PM
01/10/10 01:23 PM
Total piston to wall clearances recommended by the piston maker All minimum clearances are between the parts, valve to piston and so on
Re: Piston to wall clearence [Re: flatiron] #578518
01/11/10 11:49 AM
01/11/10 11:49 AM
NC
440Jim Offline
440Jim  Offline
NC
The way I describe it, the piston to wall clearance is the difference between the cylinder bore diameter and the piston diameter. The location on the piston skirt to measure the piston dia is specified by the piston manufacturer.
Re: Piston to wall clearence [Re: 440Jim] #578519
01/11/10 12:02 PM
01/11/10 12:02 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The bore should be larger than the piston diameter.A piston with a diameter of 4.370 and recommended .005 clearence should be used in a block with the bore at 4.375.Piston manufactures recommend the clearence and where to measure at on the piston skirt.
Re: Piston to wall clearence [Re: B G Racing] #578520
01/11/10 12:13 PM
01/11/10 12:13 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Thanks to all
Re: Piston to wall clearence [Re: B G Racing] #578521
01/11/10 01:01 PM
01/11/10 01:01 PM
organ
maximum entropy Offline
organ
that always worked for me. bore smaller than piston- bad.
