500 stroker motor with 9.1 compression #578485
01/10/10 01:07 PM
01/10/10 01:07 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Would a 500 stroker motor with 9.1 compression benefit from 110 octane racing fuel or would I be wasting my money? Thanks!
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578486
01/10/10 01:17 PM
01/10/10 01:17 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
You need to know your cyl pressure to know for sure< compression test> @ 9-1 / 110 probably be a waste of money and loss of performance
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578487
01/11/10 04:56 AM
01/11/10 04:56 AM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Is it suffering from detonation on pump gas?
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578488
01/11/10 07:42 AM
01/11/10 07:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most likely it will hurt the performance unless it
has a detonation issue(which I wouldnt think so)... JMO
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578489
01/11/10 10:44 AM
01/11/10 10:44 AM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Have not fired it up yet, still waiting for parts to drop it in. What about a mixture of 93 octane and 110, maybe 2 gallons of 110 to 3 gallons of 93 in a 5 gallon jug?
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578490
01/11/10 10:47 AM
01/11/10 10:47 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why not just 87 Octane regular ... it's a lousy 9:1 !!!
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578491
01/11/10 10:51 AM
01/11/10 10:51 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
It would if you threw on a big old turbo.....come on
Re: 500 stroker motor with 9.1 compression [Re: Stanton] #578492
01/11/10 11:04 AM
01/11/10 11:04 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
if it has aluminum heads it's the same as 7.5 to 1??
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578493
01/11/10 11:18 AM
01/11/10 11:18 AM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Ok, I get it! Thanks for all the input. Happy Racing this coming year.
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578494
01/11/10 11:23 AM
01/11/10 11:23 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
what head do you have on the motor? what are the specs?
the question about detonation was a valid one and with that much stroke, and a poor combustion chamber ( open ) and no quench will result in a detonation prone environment. Race gas might be a valid solution to the black bearings you could get as a result of that combonation.
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578495
01/11/10 11:48 AM
01/11/10 11:48 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
If it is aluminum heads, 87 octane will do the job. Iron heads may need 91-93 until you get things sorted.
I run an aluminum head 9.3:1 440 on 87 and it's just fine.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: 500 stroker motor with 9.1 compression [Re: DJVCuda] #578496
01/11/10 11:49 AM
01/11/10 11:49 AM
UK
602heavy Offline
602heavy  Offline
UK
The motor will always be a pig with that CR if using alu heads , fuel 'load up' will be an issue due to the slower burn speed , i had to mill the heads fort his very reason. (600")
An earlier closing intake valve would be a band aid , although it would help , using race gas (higher octane) is a bad idea due to spark lead having to be advanced so much it will slow the piston down.
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578497
01/11/10 11:53 AM
01/11/10 11:53 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well the 500 inches is not the requirement for octane but the final compression, coupled with cam specs and consideration for aluminum of iron heads.
A 9 to 1 motor with a 204/210 duration cam @ .050 may need some extra above 93 octane while a 275/284 @ .050 may not need any octane above 93 and may well run on less aluminum heads generally will need less octane than Iron.
Re: 500 stroker motor with 9.1 compression [Re: racealittle] #578498
01/11/10 11:58 AM
01/11/10 11:58 AM
Pasco, WA
440mag Offline
440mag  Offline
Pasco, WA
I run an aluminum heads, 496, 9.1:1 CR with 87 octane, no problem.
If I'm heading over a mountain pass I put in some 93 octane. It probably does not need it but makes me feal better.
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578499
01/11/10 12:03 PM
01/11/10 12:03 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Cast Iron Stage V heads from Mopar Performance, I will have time to test and tune it in Feb, but looks like I would not need to spend $8.00 a gallon on 110
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578500
01/11/10 12:05 PM
01/11/10 12:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
No I would think 93 would be fine what are the cam specs?
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578501
01/11/10 12:08 PM
01/11/10 12:08 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
509 lift 248 duration @.50
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578502
01/11/10 12:12 PM
01/11/10 12:12 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I just witnessed a 500" , stage V headed 509 cammed motor eat itself to detonation death. Black bearings were the dead giveaway.
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578503
01/11/10 12:13 PM
01/11/10 12:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
mild cam on a 500 but 93 should be fine. 108 lobe separation angle? degreed at 106?? start with total timing at 30 with 93 and and move up 2 degree's at a time till 36??
Re: 500 stroker motor with 9.1 compression [Re: 1AARCUDA] #578504
01/11/10 12:19 PM
01/11/10 12:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you probably need it. you do know the more octane you use the slower the burn rate right? I would start with regular 93 and work your way down.
