oil pan with stud girdle #578408
01/10/10 12:01 PM
01/10/10 12:01 PM
St. Louis Mo. USA
P
Pleaz Offline OP
Pleaz  Offline OP
P
St. Louis Mo. USA
On the new engine, i had a stud girdle put on it. My old oil pan is a super stock oil pan. With the stud girdle, and old oil pan, i will probably be rubbing the ground. Can anyone tell me a good oil pan to use with a stud girdle? Thanks.
Re: oil pan with stud girdle [Re: Pleaz] #578409
01/10/10 05:17 PM
01/10/10 05:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Milodon makes a shallow road race pan but it is very expensive.
You may find more responses to this over on the race board
Gus
64 Plymouth Savoy
Dana 60
Re: oil pan with stud girdle [Re: fourgearsavoy] #578410
01/10/10 06:35 PM
01/10/10 06:35 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
Gus
I have that Milodon pan. Its only 5 inches deep and its REALLY trick. The only problem is, they advertise that it clears stock stearing but it comes nowhere close to clearing mine. Its a great pan but plan on modifying for clearance.
-1967 Belvedere II 440/4speed
