Front tire recommendation ? #578134
01/10/10 12:53 AM
01/10/10 12:53 AM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Time for a set of front drag tires; 15x3 wheels, 3000-lb Duster, under 135MPH. I've run the Moroso 7.10 forever, never a problem, but is there a less expensive alternative? Seems like everyone's front drag tires are around $300+/pair.
Any street tires that are light, same size, good to 135, and cheaper, or do I just need to suck it up and stretch the credit card a bit further?
FWIW I'm planning to run 'em tubeless on magnesium Flys.
Re: Front tire recommendation ? [Re: topside] #578135
01/10/10 10:30 AM
01/10/10 10:30 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have used a 195/60-15 street tire that is H rated on a couple different efforts.
They hold up well and are available from a couple different manufacturers.
It is a radial , but it has never caused me a problem.
Re: Front tire recommendation ? [Re: topside] #578136
01/10/10 11:11 AM
01/10/10 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The BIG word you said was LIGHT and I dont think there
is a light street tire that fills your need... if
you want the street tire then it will weigh more but
most likely you can get it cheaper..... JMO
Re: Front tire recommendation ? [Re: MR_P_BODY] #578137
01/10/10 11:21 AM
01/10/10 11:21 AM
tboomer Online work
tboomer  Online Work
I am running the M/T sportsman fronts on my 64..Can't remember what I paid for them but they are a good tire for the money...
Re: Front tire recommendation ? [Re: tboomer] #578138
01/10/10 11:34 AM
01/10/10 11:34 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I think you have right tire on there now.
The extra bucks are worth it. If you have time look around.
Re: Front tire recommendation ? [Re: AAR-B4] #578139
01/10/10 12:30 PM
01/10/10 12:30 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks for your replies; I guess I just gotta step up.
Now that I think of it, VW Beetle sizes were what we used back in the day. Cheap, but heavier than Morosos as I recall.
Re: Front tire recommendation ? [Re: topside] #578140
01/10/10 02:05 PM
01/10/10 02:05 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I think the 7.10 Moroso's are your best bet.We have run a 215/75D/15 tire when we first ran the car(71 Demon)and it's VERY close to the Moroso 7.10 size.
Nautilus Racing-
Re: Front tire recommendation ? [Re: Chris2581] #578141
01/10/10 04:43 PM
01/10/10 04:43 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks, Chris. IIRC, about 165/78 was the Beetle size, but if course they'd be rated for something less than 135MPH - duh - and would likely be a few pounds heavier.
I have about 3 months before the season starts here, so no worries; if a deal can be found, I'll be on it.
