Front tire recommendation ?
#578134
01/10/10 12:53 AM
01/10/10 12:53 AM
Posts: 20,784 A collage of whims
topside
A collage of whims
Time for a set of front drag tires; 15x3 wheels, 3000-lb Duster, under 135MPH. I've run the Moroso 7.10 forever, never a problem, but is there a less expensive alternative? Seems like everyone's front drag tires are around $300+/pair. Any street tires that are light, same size, good to 135, and cheaper, or do I just need to suck it up and stretch the credit card a bit further? FWIW I'm planning to run 'em tubeless on magnesium Flys.
Re: Front tire recommendation ?
[Re: topside]
#578136
01/10/10 11:11 AM
01/10/10 11:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The BIG word you said was LIGHT and I dont think there is a light street tire that fills your need... if you want the street tire then it will weigh more but most likely you can get it cheaper..... JMO
[Re: topside]
#578140
01/10/10 02:05 PM
01/10/10 02:05 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I think the 7.10 Moroso's are your best bet.We have run a 215/75D/15 tire when we first ran the car(71 Demon)and it's VERY close to the Moroso 7.10 size.
